trans help please (4l60e problem)
My car doesnt have 1st or Overdrive. happened upon a start up one day i was leaving work.
It stays in third the whole time unless i manually put it in 2nd. I thought it was the pressure switch, so i dropped the pan, put in a new one...didnt help. so dumping fluid all over myself resulted in nothing. losing my patience. I believe it is just in a limp mode, but it is like that for a reason...
i was probably doing that as you typed this. ha
and crap...came up with quite a few codes for the trans.
this trans is out of an 02 z28, so idk if that would cause it to throw codes.
the trans has worked perfect for 6 months though.
P0740 - TCC Enable Solenoid Circuit Electrical
P0753 - 1-2 Shift Solenoid Circuit Electrical
P0758 - 2-3 Shift Solenoid Circuit Electrical
P0785 - 3-2 Shift Solenoid Circuit Electrical
Honestly, how can those all go bad at once? The trans worked perfect.
