P1870 help
Old 05-06-2009, 07:33 AM
predator427's Avatar
Exclamation P1870 help
my 99 camaro 3.8 auto 4l60e trany started shifting very hard from first to second. And tcc was locking and unlocking constantly.Scaned and got code P1870 any help on what I need to fix this or is trany toast?
Old 05-06-2009, 08:55 AM
mike13's Avatar
I'm not a trans expert but when you set the P1870 you will get hard shifts. I've had a couple of cars that set P1870. GM has a service bulletin and the fix was to replace the valvebody because of a worn check ball seat.
I don't know if that's your problem just saying there's hope that your trans can be fixed without a complet rebuild.
Old 05-06-2009, 09:03 AM
JUNK's Avatar
U can pull the valve body and look for a check ball stuck into the metal separator plate. Would be a good time to install the trans-go kit and a new trans-go plate.
Old 05-06-2009, 02:36 PM
ArkBird96's Avatar
ARGH! The dreaded P1870 code!
My old 1996 Firebird 3.8 did this several times. At first, when it would happen, I would just clear the code with the scan tool and it would go away for a good while. Then, it got worse and started throwing the code every drive. I finally took it in to one transmission shop, and they said the tranny needed to be rebuilt. Then, I heard of some kit that Sonnax makes (I think). I don't know what it is, but another transmission shop put it in and it fixed the problem for good.
I think all that kit does is modify the valve body and eliminate PWM for good, but I'm not sure. Hopefully this helps some.
Old 05-06-2009, 04:12 PM
JUNK's Avatar
What sonnax makes is a new L/U valve and a reamer to repair a worn bore in the valve body. The valve is cheap but the reamer runs about 100.00
Old 05-06-2009, 04:46 PM
anyone know where I can get a sonnax kit and what all do I need.
I also see that trans-go has a kit, any good?
Old 05-06-2009, 07:50 PM
LS1Tech Sponsor
performabuilt's Avatar
The transgo is fine however neither is a guarantee of a fix. If the car is high milage or if its been run like this a while the converter clutch may also be damaged in which case you will still have the problem.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-06-2009, 08:34 PM
WE TODD DID's Avatar
Pull the spring out of the tcc regulator valve bore and get a stiffer one and put in it. You don't have to buy the kit. And, as said above, if it's a high mileage unit, you may have a worn converter clutch as well.
Take the spring to a hardware store, and get one about the same diameter, and a little longer, and stiffer.
Old 05-06-2009, 08:40 PM
LS1Tech Sponsor
LOL I would have said that "BUT" I figured someone would make some "comentary" about it not being the " RIGHT WAY TO DO IT" But it does in fact work agreed
__________________
Call 888-744-6542
Old 05-06-2009, 08:41 PM
ArkBird96's Avatar
OK. Now I have a question. Why is it that the V6 F-Bodies tend to have this issue more than the V8's do? Or am I completely wrong and V8's also are plagued by this issue? My 96 V6 had this issue as well and it was at about 95,000 miles or so, bone stock. The 2000 Formula that I have now is at 105,000+ miles and shows no sign of this.
Old 05-06-2009, 09:12 PM
JUNK's Avatar
A valve wearing a bore in the body is a function of how many cycles, not miles. That being said maybe the 6 banger shifts/locks/unlocks more. The trans-go kit "fixes" this problem according to Gil Younger. After u complete that step in the directions, he praises u for "fixing" this issue
Old 05-06-2009, 09:21 PM
Motivational shift kit, huh? LOL
Quick Reply: P1870 help
