Converter co. input please
Old 05-25-2009, 11:34 AM
N20SS's Avatar
Default Converter co. input please
I recently had a converter built by a local company and it seems there was some miscommunication, and I'm not happy with my new converter. I am considering a converter from one of the sponsors here, and need some input.
I'm running a 4l60e. 346ci 475rwhp makes peak torque 425ft/lbs about 4700 and I'm shifting at 7k. 3.89 gears. Running 28" et street radials. From all I've read I probably need a converter with about 4000 stall. The kicker is I will be running a 250 shot on it. This is where I think the miscommunication came in. I wanted a converter that would get good 60ft's on motor and work well on the spray. I ended up with one that only flashes about 2800 on motor and the best I can get is a 1.68 60ft. This converter feels stock driving around and I hate it. It frys tires on the street and is killing my et's on motor. I haven't tried it on the spray. I had better 60ft's on my cam only setup with 3.23's and a vigilante 3600 before I blew up the stock tranny and ruined the converter. The only street manners I'm worried about are the lockup so I can cruise down the highway to the area racing spots. The car is not a daily driver and doesn't see much if any stop and go driving.
Can someone give some input on a good converter. Do I have to give up the good 60ft's on motor to get a good converter for the spray? I should be well into the 1.5's on motor and probably mid 1.4's on spray I think.
Old 05-25-2009, 12:39 PM
05gto60's Avatar
i just ordered a yank myself, and they would be able to help you out with the choice.
the other sponsors arent bad either, circle d or FTI
Old 05-25-2009, 02:17 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
A 250 shot is quite a bit to have your cake and eat it to. I'd put my $$ on a
Circle D 4.5C and let her eat!
G/L
Old 05-25-2009, 02:19 PM
01FbTaWs6's Avatar
FTI for the win. Give Greg a call. You cant beat an FTI converter...
Old 05-25-2009, 02:50 PM
N20SS's Avatar
Not looking for brand recommendations guys. Was hoping some of the converter companies would give me a suggestion what to go with.
Old 05-25-2009, 03:41 PM
Circle-D's Avatar
N2OSS,
I would suggest the 4C or the 4.5C like TXCAMSS suggested. Much better flash to get the 60's down. A 250 is a huge shot, but I think you will be able to eat it as well.
Chris
Old 05-25-2009, 03:48 PM
01FbTaWs6's Avatar
i posted above so you can call fti. I could care less if you go with either fti or circle d, but those are the 2 that you will have the best luck with IMHO.
Old 05-25-2009, 09:10 PM
tording99Z28's Avatar
I have owned a Yank so far and really enjoyed it but I have my new one for my TH400 swap that I am doing from Chris at Circle D. I went with the 4C+ converter which stalls just a big higher than the 4C from what Chris told me.
Old 05-26-2009, 07:18 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
LS1Tech 10 Year
We can design a converter for you that will work well with both The SRLS6391 would be my choice. As a nitrous converter generally wont 60 well without the jug and if you build a motor only converter it will blow through on the jug.So with that being said we need to build you one that meets the happy medium. give me a call and i can explain.
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 05-26-2009, 05:47 PM
N20SS's Avatar
Thanks for the input guys.
Old 05-26-2009, 06:42 PM
Circle-D's Avatar
Your welcome. Good luck with the decision.
Chris
Old 05-26-2009, 07:15 PM
2002SS#1811's Avatar
On my second Yank due to more HP/TQ I stepped up to a SS4000 and have had great luck with both so far. Give them a call.
Old 05-28-2009, 06:27 PM
LS1Tech Sponsor
LS1Tech 10 Year
your welcome
Greg
__________________
1-866-726-8358
FTIPerformance.com
Quick Reply: Converter co. input please
