Transbrake solnoid spewing fluid?!?
Old 06-01-2009, 09:58 PM
Raven02TA's Avatar
Default Transbrake solnoid spewing fluid?!?
TH400 trans
Like the title says, im not familiar with the solenoid itself. it seems its held in by one bolt with a forked tab.
heres the story. went to the track about a month or two ago. everytime i would stall the car using the brake (using only about 5-7 secs) it seems the fluid would blow through around the base of the solenoid?
could anyone help me understand how to prevent this from happeneing. is it an O-ring around the base of the noid? is the noid screwed in also etc. (before i take things apart and not know what im doing)
Old 06-02-2009, 07:06 AM
rsm425's Avatar
There should be an o-ring (just like a vacuum modulator has) on the solenoid.
Old 06-02-2009, 07:11 AM
built408's Avatar
You also might need to bend that tap alittle to make sure there is pressure up against the solenoid.
Old 06-02-2009, 07:40 AM
Raven02TA's Avatar
thanks fellas, ill give it a go in a week or so. soon as i can get her up on a lift. i just wanted to know what i was in for. it seems though i can actually rotate the solenoid by hand i had a suspicion it was an O-ring in there which now i have confirmation.... now i just have to check things out and bend the tab i guess to make it tighter.
Old 06-08-2009, 09:29 PM
Raven02TA's Avatar
anyone know where i can buy the O-ring from? before i tear things apart.
Old 06-08-2009, 09:55 PM
Lone Warrior's Avatar
any trans shop will have them, even a NAPA store should
Old 06-09-2009, 07:04 AM
FLT
FLT's Avatar
I have seen in some cases where two modulator brackets are needed in order to keep the solenoid in place. Might be something to think about. Vince
Old 06-09-2009, 07:09 AM
Raven02TA's Avatar
thanks, i may order another just as a precaution. we will see how things go after i change out the o-ring this time.
