do i need a bigger converter
i have a 2001 ram air and i am swapping out cam it is a a4 with a 2800 stall. i have pacesetter lt and 3 inch true duals. 4.10 gears full bolt on a 228r cam on a 114. i got a good deal on a 236/242 .580 .590 on a 112. do in need to go to a bigger stall to go with this cam or will it be fine. i have a great tuner that tune my car. thanks in advance
Your current stall is low for the 228, in my opinion. Def will be short with the new cam you are looking at. I would probably go with a 3800-4000.
If you use your car on the street mostly I, PERSONALLY everyone else, would not even change the cam. Order up a 3800-4000 yank, Vig, C-D etc and you will be happier than changing the cam.
I bet it would pull like a biotch.
That cam will love a higher stall converter. You could get by with the 2800, but it will not have power down low. The higher stall converter will put you in the power band, make the car an animal. 3600+, might even suggest a 4000. Is this a DD or just a weekend toy?
Chris
Chris
That car would be a dog with a big cam and that baby stall. Get a 4000+ converter so you can get into the power fast and have better shift extensions.
A friend of mine use to have a 3500 stall and an MS3 and even with that combo it was a dog until the power really started coming on at like 4000-4500.
i would love to have a ss4000 or pt4000. i guess i will start saving up for a new converter and wait to put the cam in then. what is the differance of the ss and pt series.
LS1Tech Sponsor
As others have said. you actualy need more converter with what you have for optimum performance. If it is a DD then 3800-4000. If your intention is to not run the jug. If you were to put the jug to it then 36-3800 with a different stator would be my choice.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
