4L80 tune no longer *required*
Old 09-28-2009, 09:13 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by bustac
I'm doing a similar swap right now, I have 2000 5.3 stock pcm and tune for a silverado. Right now I haven't fired it up yet. I have an earlier style 4L80E so what all what would I need to do as far as tuning?
I have the stock 2000 silverado engine/trans wiring harness too not sure about trans connections either. My tranny has the large round connector and a single two pin connector?
You can do my method (PM me) or buy a conversion harness. Unless you scrounge around the junkyard my method is probably a little cheaper.
slow67 is offline
Old 09-30-2009, 06:59 AM
Restricted User
Vortech Converters's Avatar
Default How Do You like That Converter?
How do you like the converter from the small guys?
Vortech Converters is offline
Old 09-30-2009, 11:23 AM
Gingervitis Addict
slow67's Avatar
Works great Thanks! I'm really gonna put the screws to it in February.
slow67 is offline
Old 10-01-2009, 09:50 PM
Nimitz87's Avatar
so let me clarify this you DO NOT have to merge files now?
I'm in the midst of getting ready to do a 6.0/4l80E swap into my M6 99' TA
I purchased the LSXtune M6 to 4l80E harness adapter...I had planned on merging files, if I can load up a 4l60E file and make it work that would be fantastic....
Chad
Nimitz87 is offline
Old 10-02-2009, 09:21 AM
Gingervitis Addict
slow67's Avatar
Chad
That's the idea.......PM me for the details.
slow67 is offline
Old 10-06-2009, 08:09 AM
White.Lightning's Avatar
Subscribing. Sending PM now.
Thanks
White.Lightning is offline
Old 10-06-2009, 06:54 PM
built408's Avatar
No offense, but this has been done a long time ago.
built408 is offline
Old 10-06-2009, 07:39 PM
Nimitz87's Avatar
more info on this?
Chad
Nimitz87 is offline
Old 12-07-2009, 09:28 PM
Red Heartbeat's Avatar
You say you had a change of heart in the first post? Care to explain? Are you using the 60e tune now or did you go ahead and use the 80e overlay to control the trans?
Red Heartbeat is offline
Old 12-18-2009, 11:15 PM
rsz288's Avatar
Yeah ditto. More info. It might have been done a long time ago, but if no one knew about it, so what. At least this guy has figured it out, done it and shared it in the public domain. Kudos to him.
rsz288 is offline
Old 12-19-2009, 09:08 AM
Gingervitis Addict
slow67's Avatar
Well I did leave out 2 important pieces of info left up to the reader to figure out (or PM me).
I am still running the 4L60 tune and it is my daily driver as well, so it has been fairly thoroughly tested.
slow67 is offline
Old 12-26-2009, 09:22 PM
  #32
robbyredneck's Avatar
doing the same with 03 yukon lq4 but with 4l80e. please pm "secret" thanks robby
robbyredneck is offline
Old 01-12-2010, 06:30 PM
  #33
MUSTANGBRKR02's Avatar
How are your VSS sensors hooked up? WHich one of the two are you using? to which pins on the pcm or stock harness?
MUSTANGBRKR02 is offline
Old 01-12-2010, 06:56 PM
  #34
Gingervitis Addict
slow67's Avatar
VSS is same as a stock (4l60e). Rear only (both are 40 teeth).
slow67 is offline
Old 01-12-2010, 07:10 PM
  #35
Mine is not working when installed in the back only any ideas? I already had a 60-80 adapter harness.
Old 01-12-2010, 08:48 PM
  #36
Gingervitis Addict
slow67's Avatar
Should be C2 20 and 21.
slow67 is offline
Old 01-16-2010, 10:52 AM
  #37
FrankSS's Avatar
so what is the secret this said info that you are withholding? i am going to be doing the swap before too long as well, and would rather do this than try to merge files. pm me
FrankSS is offline
Old 02-05-2010, 12:00 PM
  #38
5LTRETR97's Avatar
Very interested. I would like to know the secret as well. Thanks.
5LTRETR97 is offline
Old 05-18-2010, 09:49 PM
  #39
Ryan33187's Avatar
Can you use both the VSS and ISS sensors or should you just use the rear sensor?
Ryan33187 is offline
Old 05-19-2010, 04:42 AM
  #40
VSS only (rear sensor)
Quick Reply: 4L80 tune no longer *required*
