700R4 swap into a 00 SS???
Old 09-26-2009, 03:42 PM
Justins00ss's Avatar
Default 700R4 swap into a 00 SS???
Well Ive just about had it with my M6 setup. Ive thought about going to a 60E but dont want to deal with all of the electrical crap. So I was thinking of doing a 700R4 instead with a full manual valve body. I do have a few questions too.
1. How do I make the speedo work?
2. What style converter would work? Do I use a ls1 style converter and flexplate?
3. What crossmember do I use?
4. What year 700R4 should I look for?
5. As long as the tranny is a full manual valve body I shouldn't need the TV cable?
Old 09-26-2009, 03:46 PM
madmike9396's Avatar
man ive only heard horror stories about these trannys i would use a th400 or th350 just my opinion
Old 09-26-2009, 03:48 PM
13lu91rS's Avatar
700r is junk man my buddy went thru 3 built ones in his thirdgen (5.0 with headers and a carb)
go with a th400
Old 09-26-2009, 03:52 PM
Yeah the problem is that with TH400 or TH350 and 4.10s I lose all drivability. I know you can build a high horse 700R4
Old 09-26-2009, 04:03 PM
just get a taller tire, idk good luck to ya
Old 09-26-2009, 04:22 PM
Super Speed's Avatar
Have you looked into the 4l80e?
Old 09-26-2009, 07:41 PM
PedaltoMetal's Avatar
1. How do I make the speedo work? Later model 700's come with a VSS in the tailshaft.
2. What style converter would work? Do I use a ls1 style converter and flexplate? No the LS style converter will not work. You need the older converter syle. The LS flexplate has a 300mm bolt cirlce. The converter you need is 298mm. You can either modify the stock flexplate and add a spacer if it needs it or get a one designed for the swap.
3. What crossmember do I use? Stock one should work since they share similar dimensions but will have to get the tailshaft with the torque arm mount or move the mount to the crossmember.
4. What year 700R4 should I look for? Any 87 and later2wd is best but the newer the better. The 4x4 "K" case is stronger but harder to find and you'll have to swap output shafts and tailshafts. Make sure it's one from behind a v8 or 4.3 V6 only.
5. As long as the tranny is a full manual valve body I shouldn't need the TV cable? Depending on where you get it, no cable needed with a full manual valve body.
Don't let people fill your head with nonsense. 700's can be made plenty strong.
Old 09-28-2009, 05:12 AM
frankmarroquin's Avatar
^^Wow plenty of help man, I am planning on the same thing... I just got a Spare LS1 and a poor carburated Corvette. So I think I smell another Project.....
