transmission trouble
well i have a 4l65e fully built i recently replaced my stall from a 3400 to a cirlce d 3800 4c i drove it for a couple days after install with no problems i took a 400 mile trip with no problem on my way back problems started.........
1st. temperature raised from 160 to 210
2nd would not shift into 3rd
3rd rpms would reach 6000rpm and still no shift
4th speed will not go over 45mph
what could be the problem?
Did your Service Engine Soon light come on? Did the trans stick in 2nd gear (limp mode)? Did you immediately stop the vehicle as not to hurt the trans? You will need to get a scanner and see what is going on. Try to get more info, what vehicle is this in, codes, etc. You may have needed to make some small adjustments when you raised the stall speed, but I don't feel this was the problem.
AFAIK there is no "safety sensor" on the 4L60E. Apart from checking the fluid, the only way you would know the fluid level is that low would be if the tranny fails completely.
