Cooler Hook-up
Old 01-14-2010, 09:07 PM
Formula/LS1's Avatar
Default Cooler Hook-up
I'm just wondering, "do you hook up an auxiliary trans cooler in conjunction with the radiator or do you run the trans cooler by itself to the trans? I have a Perma-Cool with 1000cfm. fan kit. Thanks.
Old 01-14-2010, 09:35 PM
The Fugitive's Avatar
you can run it either way it's personal preference i have mine in conjunction and it's been fine some just run it by itself. The reason I did mine that way is just for extra cooling because i have the 4L80
Old 01-17-2010, 11:25 AM
Thanks, I appreciate the help. Is there a preference as to go through the radiator first then the cooler or vice versa?
Old 01-17-2010, 01:19 PM
PontiacFan's Avatar
Radiator then cooler, ...
https://ls1tech.com/forums/automatic...kies-here.html
Old 01-18-2010, 07:20 AM
Originally Posted by PontiacFan
Thanks again !
Old 01-18-2010, 06:27 PM
barnat's Avatar
Ide say just run threw a trans cooler .But then again i had a bad rad that leaked or mixed tranny fluid and coolant together inside my rad a few years ago which totally ruined my brand new Rossler (stage 3) 4L60 and all of my coolant hoses. I run mine now threw 2 BMR coolers mounted on my front air dam and it stays at 160 all day long (Even is the hot summer months)Its just something that can happen to ruin your year i guess .I always felt its better to keep the 2 systems seprate if at all possible because that way NOMATTER WHAT,one cant effect the other if something were to happen. Plus,its always easyer to just change out tranny coolers in the event of a blown tranny verses trying to remove and clean your rad of tranny debrie or F.O.D
Old 01-18-2010, 06:32 PM
MUSTANGBRKR02's Avatar
I also vote just external cooler mine got plugged up and burnt up the tranny.
Old 01-18-2010, 06:50 PM
barnat's Avatar
You too huh? LOL I had the plugged rad ruin a tranny on my 87GN some years back and didnt know till i put the secound one in Thank god i installed a trans temp gauge before installing the secound tranny.The mixing thing with the tranny fluid and coolant happened to me 2 years ago on my present 02 SS after installing a brand new (Be Cool) rad and i swore to myself after that ,,,that ide never use a rad cooler again for my tranny!
Old 01-19-2010, 06:56 PM
382ssz28's Avatar
Most engines run between 180*-210*. Run only the cooler, especially if you have a stall converter. You only need to run in conjunction if it is a year round vehicle as the engine heat will heat the trans fluid faster in the winter. The cooler alone will run 20*-30* cooler than with the engine coolant in the radiator. This arguement has been going on for over 40 years.
Old 01-19-2010, 09:12 PM
Paul57's Avatar
X 2
Running the fluid through the radiator will heat your fluid...contrary to what most of us are trying to achieve. If it is a year-round vehicle (especially in the nothern states) you can run both. If it is a summer only vehicle then use the external cooler only.
Old 01-20-2010, 07:28 PM
1mean96ss's Avatar
Is there a way to plug the radiator port ?
Old 01-20-2010, 08:32 PM
Thanks everyone. I really appreciated ALL the feedback.
Old 01-21-2010, 11:26 AM
Reboot's Avatar
No need...They are just empty dry passages. I just bypassed and left them opened. I did run some brake cleaner through so I would drip any left over ATF
Old 01-29-2010, 05:19 AM
99corvette's Avatar
what coolers are you guys running? I installed a tranny temp gauge and mine is running at 250 degrees. I wanna run mine just through the cooler, but dont think mine is big enough
Old 01-29-2010, 10:37 AM
green28's Avatar
Good info. I just bought a 24,000 GVW B&M Supercooler along with a SS4000 stall but have yet to put anything in yet. I plan on running the trans cooler "dope style" and after what I've read in here, just using the cooler and not the radiator cooler.
Old 01-29-2010, 04:15 PM
99Hawk262's Avatar
I run a B&M 24K mounted dope style, then a large Hayden cooler mounted on my radiator. I also have a SLP fan switch that when turned on high will drop the temps another ~10 degrees because of the air being pulled through the cooler. With my PT4400 and my Circle D 5000, my cruising temps are roughly 150* and my stop-and-go temps are around 180*.
Old 01-29-2010, 05:19 PM
99corvette's Avatar
What is the "dope" type?
Old 01-29-2010, 07:23 PM
99Hawk262's Avatar
In a nutshell, it's mounted horizontally underneath either front corner of the car. I don't have pictures, but do a search and plenty of posts should come up.
Old 01-30-2010, 08:31 AM
99corvette's Avatar
Does anyone know the torque specs on the tranny pan bolts?
Old 01-30-2010, 09:02 AM
Circa307's Avatar
this is the tranny cooler ill be running without rad. Its for my new ss4k stall . wanted to do as big as possible. i want to bypass rad for simplicity and maybe it will be easyer on my tranmission fluid pump.
Quick Reply: Cooler Hook-up
