identification of 4l60e
I picked up a 4l60e and I am trying to find out what year and type of vehicle it came out of. They usually have a tag with like a bar code on it but the tag is gone on this one. it has a couple of casting numbers on it . One is 24206952 that one is on the out side of the case. The other one is inside where the converter goes by the input shaft and it is 24201073 and under that it has g-72a f. I did some searching but didn't really come up with any thing.
Well considering there are only the numbers that I listed on the transmission I was hopeing it could be identified. The link you left did not help but I appreciate it any way.
You won't get any help with those numbers the first one is for the tail shaft assembly or whatever and the last one. Well you saw lol. Im curious to why your wondering what it came out of.
I picked up a lq4 to install in my coupe mustang and the guy had this 4l60e instead of the 4l80e that should have came with the lq4 I guess some one swapped it on him I don't know but I guess either way this 4l60e should bolt up and work with my lq4 for my fox body coupe swap Im doing.
