have a few questions before i dive into the tranny cooler install
Old 04-03-2010, 11:11 PM
twitchtwice's Avatar
Default have a few questions before i dive into the tranny cooler install
Im going to be mounting my cooler in front of the radiator and will be bypassing the stock cooler per recommendation on this forum. i have a few questions (probably easy, just for reassurance). I will attach a picture of exactly how i will be mounting it.
1. In order to mount the top part of the cooler to secure it will i need to remove my lid and lower air box to access bolts to finish the install or is the bottom bracket going to be enough to hold it in place?
2. Do i just disconnect the lines from the radiator and attach the new hoses on the ends of those to run into the cooler?
3. Does it matter which ends you use for in/out on the cooler?
thanks in advance
Attached Thumbnails have a few questions before i dive into the tranny cooler install-cooler.jpg
Old 04-04-2010, 12:33 AM
7th Darkness's Avatar
1. Guess it depends on how stable it is with just the bottom secured.
2. YES
Old 04-04-2010, 02:00 PM
finished up my install. drove it for a good half hour and it didnt go past 130. mission accomplished lol.
Old 04-04-2010, 07:39 PM
Ahh good to hear.
Old 04-04-2010, 11:47 PM
memphis24's Avatar
havent done this mod yet. its next on my list. Seems pretty straight fwd
Old 04-05-2010, 07:48 AM
Sykokilla's Avatar
Easy as pie good job man.
Just for search purposes NO IT DOESN'T MATTER WHICH ENDS YOU USE FOR THE IN/OUT ON THE COOLER.
Old 04-05-2010, 08:23 AM
01ssreda4's Avatar
what cooler are you using??
Old 04-05-2010, 11:00 AM
yes it was much easier than i expected. i actually installed it much different then the picture since it was much easier the way i did it.
this is correct, it doesnt matter
uh i cant remember the numbers but its the one that you were using before, 7264? i think im missing a number in there haha. i know its the 24k
Old 04-05-2010, 11:39 AM
01ssreda4's Avatar
70264?? yeah thats a popular cooler around here. It does the deal as long as its got some air flow.
Old 04-05-2010, 12:04 PM
ArkBird96's Avatar
is there a way to do this without trans fluid spilling out anywhere? Also, is this a good mod for a car that has a lid but otherwise stock?
Old 04-05-2010, 12:10 PM
yeah as far as i can tell it will be plenty of cooling for my car. especially since i may be moving to virginia from texas, its much cooler there lol.
yes, a little will come out but only whats in the lines. if you unplug it and immediately point the hose up nothing will really come out.
its a good mod because it will only help the car. especially if it still has the stock stall it will keep the temperatures down well.
Old 04-05-2010, 01:13 PM
ArkBird96's Avatar
That's what I thought. My Formula is a DD so it spends a lot of time sitting in Atlanta traffic in the summer with the A/C on, so that might be a good idea. It also still has the stock converter, so that might be a good mod. How much would it cost me and what all would I need? The last time I went to Summit I saw several different coolers there, and I've heard that the stacked-plate design is better.
Old 04-05-2010, 02:00 PM
the cooler i installed is the 70264 and it comes with everything you need and its 60 bucks. cant beat that. the good thing about that cooler is that if you do end up putting a stall in later you can keep that cooler
Old 04-05-2010, 06:58 PM
gc302047's Avatar
could you tell me how you did this im doing the same thing and a little instruction would help me out a ton
Old 04-15-2010, 02:44 PM
joecar's Avatar
Where did you buy the cooler from...?
Thanks.
Old 04-15-2010, 03:40 PM
Gatsby's Avatar
See our thread in this section called BM 70264, i have pics in there of how i did mine and what exactly i did to install it. Worked out really well.
