Stock 4L60E and a stall
Old 04-08-2010, 10:40 AM
nitr0racing21's Avatar
Default Stock 4L60E and a stall
Whats the most power I can have a stock trans with a stall under??
Old 04-08-2010, 10:50 AM
therealcreeper's Avatar
LS1Tech 10 Year
you will not get a reliable answer without more information. mileage of trans? how big of stall? what kind of power (i.e. nitrous vs motor)? will you leave torque management on? do you plan on adding a cooler?
they're rated at 360rwtq but that's probably with torque management on and on the stock converter. aftermarket ones add a lot of heat. some blow up under stock power, others survive 475rwhp for years.
Old 04-08-2010, 01:41 PM
rice4eatingnotdrivin's Avatar
i dont no but ill beable to tell u after april 15 when i take my car to do some more testing..... i have a stock 4l60e and im making about 550 to the tires lol ill let u know if it holds...
Old 04-08-2010, 05:20 PM
dannyz's Avatar
LS1Tech 10 Year
Damn. That's gotta be a new record if it holds together for more then a few passes.
Old 04-08-2010, 08:52 PM
the car went in the 10s on a safe tune with stock suspension stock 10 bolt with the stock gearing and stock trans with a vig 4000 stall converter speed incs SI5 cam and some nitrous
Old 04-08-2010, 08:57 PM
TXZ28LS1's Avatar
figuring out how long a stock trans will last is a million dollar question? LOL...
Old 04-08-2010, 09:21 PM
i have a th400 to put in the car once the stock 4l60 goes.. thought i would test the trans out and see how long it will last
Old 04-09-2010, 01:27 AM
blackhawk0251's Avatar
Yeah man 550 to the wheels is a little much through a stock 4L60e..
Old 04-09-2010, 02:11 AM
edwardzracing's Avatar
Talk about being on borrowed time, lol. Just hope **** doesn't break at the top end while doing 120. Be safe man. You got guts, lol.
Old 04-09-2010, 01:49 PM
everyone wonders how much power it will handle and i say ive made about 4 pass on spray going 3 11.0 pass back to back then finally 10.95 (before i had it tuned which was yesterday and it made even more power).. the only reason y it is holding up is because a 4000 vig is not a good converter for nitrous. in my opinion its way to sloppy and it absorbs most of the hit from the nitrous.... otherwise if i had a yank 3200 stall i guarantee i could get the car in the low 1.4 high 1.3 60fts but b4 that even happend my trans would more than likely be in a million pieces
Old 04-09-2010, 03:11 PM
twitchtwice's Avatar
anything under 400 you'll probably be OKAY, but you never know, it could go out at any time even under stock power with the stock stall
im making 350hp/365tq and i have no doubts that my transmission will be fine. but i never go to the track and i dont really drive the car very hard. plus i had my transmission looked at when i had my shift kit installed and everything looks great in there. granted mine only had 38k miles when installed.
Old 04-09-2010, 05:43 PM
dannyz's Avatar
LS1Tech 10 Year
Thats been my experience so far. I make 373 rwhp na/425 with the juice And I have mucho 1/4 mile runs at the track w/o any issues at all.
Old 04-09-2010, 08:45 PM
TXZ28LS1's Avatar
well in that case, run it hard till it blows..
Old 04-10-2010, 04:56 PM
lol i plan on it.. i just pray it holds on thursday if it does break i hope its not on the big end like edwardzracing said
Old 04-11-2010, 09:54 AM
I don't know how much power I am making but it should be sub 320RWHP(Headers lid TB) it has 68500 miles on it
Old 04-11-2010, 10:13 AM
01ssreda4's Avatar
Old 04-12-2010, 10:31 PM
u should be fine i made 380 and drove my car EVERYWHERE with a 4000 stall and went to the track 4 times last year... never had a problem
Old 04-12-2010, 10:40 PM
02sleeperz28's Avatar
Just depends a few variables...what size stall, trans in good shape and etc. I have a RPM trans with a 3600 stall. I didn't want the headache of worrying about if my stock trans would hold up. RPM has a great reputation so I trust that it will hold up against what I am throwing at it. Good luck
Old 04-12-2010, 10:49 PM
1BAD_LS1 Tunes's Avatar
I think a stall helps your trans hold on a little longer also higher shift pressures and faster shift times to keep it from slipping....
i ran my 4l60e with a cam only setup, then a heads cam setup, then an sts setup and then my current front mount setup at almost 600hp running the hell out of the car... the trans was stock with a vig3600 and never seen less than 400hp while i had it in (about 8000 miles). Now im running a RMVB th400 with brake..
Although i just got the trans tore down and am in the process of a rebuild because its going into my fiancees car. The clutches and bands are just about shot though! Would have made a few more wot runs and thats about it...
Get a tune to bump the shift pressures and faster shift time and that will help it last a little longer.
