4L60E No Power to plug
The following users liked this post:
Blac94z28 (08-21-2019)
LS1Tech Sponsor
I think you may find the info you need in this thread near the bottom
and PE is not fed from the pcm but from the fuse box
https://ls1tech.com/forums/automatic...sh-more-2.html
__________________
The trans plug is getting 15.6 volts to pin E and 16.2 at the battery. Is this too much and making the 3-2 solenoid hold? I just bought a new volt meter so I guess its reading correct.
Thanks,Gary
Thanks,Gary
I found the problem. The 3-2 solenoid wire was in pin C1-71, and suppose to be in C1-79. It shifts like new now, and thanks for all the advice. I guess harness manufacturers make mistakes too.
4l60, 4l60e, default, electric, electrical, l460e, pin, pins, plug, power, test, trans, transmission, transmissionpcm, transmisssion
