2000 vette having shiting problems
Old 05-26-2010, 03:25 PM
silver-vette's Avatar
Default 2000 vette having shiting problems
I have a 2000 vette and am having some problems with the car. Whenever go WOT the car will then begin to shift very hard under normal driving conditions, even chirps the tires. Also will do that when I rev the car up when parked sometimes. Any help is appreciated
Old 05-28-2010, 07:50 AM
Does anyone have any idea why it would do this?
Old 05-29-2010, 05:32 PM
LS1Tech Sponsor
performabuilt2's Avatar
I am confused as to what you arwe asking, AT wot the trans hould shift a little harder than normal..only thing i could think of is that something is slipping and a slip code is being set and the PCM is raising line pressure to compensate
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 05-30-2010, 06:02 PM
ok sorry, i guess that was a little confusing. I posted that from my phone so it was a little short. Let me try this again. When i get on it (go WOT) the car shifts great, nice and hard. The problem is that after i get on it then when i drive normal (with out going WOT) the car still shifts very hard and chirps the tires. Some times when i rev up the car when it is in park and then begin to drive normal, it will shift very hard and chirp the tires.
Old 05-30-2010, 06:38 PM
LS1Tech Sponsor
have you had any tuning done exspecially with the line pressure settings. if you can scan it look and see if you have any transmission codes (slip) codes this will raise line pressure also.
__________________
Old 05-31-2010, 09:37 AM
Yes it actually has been tuned, and he did tweak the transmission. By checking the dash I have a p1571 code. So what should ii do
Old 05-31-2010, 11:58 AM
LS1Tech Sponsor
http://www.gearchatter.com/viewtopic8503.php
__________________
Old 05-31-2010, 12:19 PM
So would this cuase the shifting problem? Should I have the transmission set back to stock? Thank you for the help
