Building strongest 4L60E possible - need advice
At the track yesterday and 3rd gear started slipping. Trans built 2 years ago with good parts including a 29 element dual cage input sprig assembly and new 3/4 clutch pack.
I thought this build would be fine for a stock motor car that runs low 12s.
Please give me a list of what the strongest parts are available for my next build.
Thanks!
Thanks!
LS1Tech Sponsor
Thanks!
Thanks!
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
"All Motor 9 Second club member"
There is much more to building a strong 4L60E than throwing better clutches and servos at it. You should be able to beat on yours at that power level for years without issue.
We ran our Circle D Transmissions 4L60E for 2 seasons running high 9s and low 10s and never broke or over shot a shift, then we had them build us powerglide. We also run a Circle D 4L60E level 2 in our 11 second daily driven car that has 2 bracket racing seasons on it without issue. The better transmission builders have their own tricks as well as an over sized 3-4 drum that holds more clutches that have quite a bit more surface area. There's just a lot they do that a basic rebuild doesn't cover . They do cost more, but it costs less in the long run, not to mention the peace of mind it offers.
Spend your money wisely and go with a Circle D Transmissions built 4L60E or an FLT. You will not be dissappointed.
G/L
G/L
No problem man.
You can go to the link in my sig and there are 4 videos of us making passes. All except the 5.99 1/8 mile pass are with our with our Ultra Strong Circle D 4L60e with a transbrake. The 5.99 pass was with our powerglide and a 445 ci engine. We had to tame the car down with the powerglide after it went on the bumper
LS1Tech Sponsor
Check out RPM Transmissions at the above link. We have used their Stage V at 700 rwhp. Bob
__________________
I honestly don't think you can go wrong with Circle D, Performabuilt, FLT or RPM. Take your pick. Call each one and talk to each one. I like Performabuilts warranty. You can't beat a 1 year warranty and if you buy the converter from them the 2 year warranty with a transmission.
We are having a special on RPM Products right now if you are looking at upgrading your transmission through them.
https://ls1tech.com/forums/sponsor-s...tial-sale.html
