straight cut gears
Old 06-26-2010, 01:46 PM
forcd ind's Avatar
Default straight cut gears
some 4L80E's i thought had the straight cut sun gears-where they used in spec. appls. for some reason
Old 06-26-2010, 04:32 PM
72blownvert's Avatar
Originally Posted by Bro Inc
I'm starting to think those don't exist.
My trucks 4L80E came out of a 1999 3500HD tow rig, it doesn't have straight cut gears.
My friends dad bought a 88 GMC 2500 off the lot. I bought it in 2003 and rebuilt the th400 that had HD cast on the top. No straight cut gears.
I've had access to an abandoned hardparts shop when it was being cleared out for demo. I've seen literally hundreds of th400 gear sets, and none were straight cut. I even picked up a 12x12x12 box of sun gears, none straight cut. I found some rare stuff there like switch pitch parts, sprag type plantetaries, etc.
I've never even seen a picture of OEM straight cut gears.
I can tell you they do exist.There just is not alot of them out there.Most of them do come out 3500 hd trucks or motorhomes but for some reason they all do not have them.Most of the ones that had them were takin out when they got rebuilt.
Old 06-26-2010, 07:21 PM
tptrans's Avatar
They did exist, but do to complaints about the whine in first gear they went to helical cut gears.
Old 06-26-2010, 09:20 PM
jakeshoe's Avatar
I've got two sets of straight cut planets sitting on the shelf.
They only came in extremely HD applications. 1 ton trucks didn't get them.
Motorhomes and other very heavy chassis.
Straight cut planets are actually weaker but they don't thrust load the pinion washers under extreme loads like a helical cut.
Old 06-27-2010, 03:55 PM
ArkBird96's Avatar
Wouldn't straight-cut gears whine like a banshee? I think the transmissions used in some school busses was an Allison 545RE which had straight-cut gears. Those things whine! Would straight cut gears in an 80e do that?
Old 06-27-2010, 05:35 PM
Yes they do whine.I have a set in my chevelle but its not to noticable over the blower and exhaust.
Old 06-29-2010, 05:37 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
i got a set. give me a call jim
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 06-29-2010, 08:32 PM
built408's Avatar
I've got a set in my car. They whine, but it's not very noticable over the exhaust.
Old 06-29-2010, 08:34 PM
forcd ind's Avatar
Greg, i'll be down there Thurs or Friday, plan on stopping by, your about 30 mins from my sons-gonna drop off some stuff for the kid, gotta find out his schdule w/Nascar stuff first
Old 07-05-2010, 06:31 PM
PBA
PBA's Avatar
Jakeshoe, you are the first builder that I have talked to that has ever admitted to the straight cut gears being weaker. Back in the early 1970's I found this out with M22 transmissions. They were noisy, slightly weaker and more costly than a good built M21 unit.
Old 07-05-2010, 06:49 PM
jakeshoe's Avatar
Dana,
You know me, I don't BS and I don't sell it either.
The straight cut planets have their place, but they are not needed or wanted in your average "hot rod" transmission.
1. Easier and less costly to produce
2. Noisier
3. Prevent thrust loading
4. Weaker at the gear face due to less surface area.
Many builders assume that because they are "rare" or were only used in very heavy applications that they must be better, when the fact is, because they are cheaper, the OEMs would have used them more but they would have had customer complaints.
I only use them in monster trucks (due to the sheer weight of the truck at 10K lbs) or the motorhomes, etc they came in.
Old 07-06-2010, 07:44 AM
You must have talked to alot of builders that do not do performance work or don't really know.I thought it was pretty much known that the straights are weaker than helicals,The fact that they are rare is the allure that alot of people want them and the assumption is that they are stronger.
Quick Reply: straight cut gears
