How much converter for a 1.8 60ft. time?
Old 06-28-2010, 12:56 PM
Old School Heavy
speedtigger's Avatar
Default How much converter for a 1.8 60ft. time?
The car:
3700 lbs
5.3 9.5:1 with 224 @.050 cam
4l60 trans
3.73 gears
Minimum size stall converter to acheive a 1.8 60ft time?
Old 06-28-2010, 01:05 PM
twitchtwice's Avatar
yeah with a good set of tires it wouldnt take much to get those times. i had a 3200 edge that was putting me at 1.9 with the absolute worst launches in the world .
Old 06-28-2010, 01:11 PM
WhitePhoenix99's Avatar
What are your current 60' times with your setup?
Old 06-28-2010, 03:14 PM
WrenchinMonkeys's Avatar
I would go with anything above a 3000 stall...you will absolutely love it and with a good set of tires...1.60-1.80 60ft. times are achievable
Old 06-28-2010, 04:55 PM
thunderstruck507's Avatar
my best is a 1.79 so far, slightly spinning nitto drag radials
yank ss3600 and I love it on the street, very tight
Old 06-28-2010, 07:11 PM
Moderator
jimmyblue's Avatar
In my experience, suspension and tires matter more.
Can't get below 1.9x, spinning all the way out, on
street tires or MT ET Streets.
Old 06-28-2010, 08:11 PM
Old School Heavy
Thanx Thunderstruck. Is that with the Chevelle in your signature? Also, that Comp Cam in your signature, is that 224 intake - 230 exhaust? How do you like that cam?
Old 06-28-2010, 08:13 PM
ULTIMATEORANGESS's Avatar
i got a 1.7 60 on my shitty midwest 3200 and nittos.
Old 06-28-2010, 08:20 PM
Old School Heavy
How much cam are you running?
Old 06-28-2010, 08:24 PM
at that time stock cam i think.
you know what. i had an 02 ls6 cam.
Old 06-28-2010, 08:26 PM
lemons12's Avatar
A 3000 converter could cut those times..
But why so small and such a slow 60' goal?
Old 06-28-2010, 08:30 PM
skat's Avatar
I cut alot of high 1.6 60's with my 3600 on M/T Sportsman Pros 26/9.50 on some old salad shooters. My mods are in sig. Motor is 100% stock, rear end and gears too.
Old 06-28-2010, 08:49 PM
Old School Heavy
This is a street car. I know that my suspension will deliver on a 1.8 on my street tires. I am not building this car for slicks or drag radials. I just want enough converter so it is not lazy.
Old 06-28-2010, 08:58 PM
Mike Morris's Avatar
With the right converter it will be easy. I have a 3800 billet and have driven the car in traffic,3 hour trips blah blah. At the track with Mickeys 1.7s everytime with stock rear. Hell I would have gone with a 4000 stall if I did it again with the stock cam.
Old 06-28-2010, 08:59 PM
SAPS's Avatar
i got a 1.8 on my first time ever to the track on street tires!
see sig.
Old 06-28-2010, 09:02 PM
SMALLBLOCKHERO's Avatar
im basically stock 100k, with headers and a SS3600 yank and 3.73's . it cuts consistant 1.80's on DR's. I should be cuttin 1.7X's regularly.
Old School Heavy
see sig.
That is good to hear. I really want the tightest converter that will deliver a 1.8. I generally find high stalls annoying on the street. You are the 2nd person I have seen running a fairly tight converter with the 224/230 cam. Is that the Comp Cam?
Old 06-28-2010, 09:03 PM
lemons12's Avatar
If that is all you want.. Go 3000-3200. I of course suggest more... But if that is truly all you want, it will meet your goals and make you happy.
Old 06-28-2010, 09:04 PM
lemons12's Avatar
Look at something in a 2.2 STR, that will help on keeping the "tight" feeling on the street.
Old 06-28-2010, 09:13 PM
Old School Heavy
This Stall Torque Ratio is something new to me. That terminology was not used back in the day when I was racing. I will tell the guys at the converter company that I want it to drive "tight" on the street. I am just glad to hear that you can specify such things these days.
Quick Reply: How much converter for a 1.8 60ft. time?
