4L60 Locks up in low
The trans in my Nova is doing something that is new to me. The car quit the other day so I hauled it home. It was running fine, just quit firing. I found a loose hot wire and solved the problem. I unloaded it to drive it again and when I go to drive the trans goes to 2nd. I can manually shift to 1st and the car STOPS....feels alot like activating a transbrake, which it does not have. Any ideas?
It is a 72 Nova with the LS1/4L60e out of a 2k Camaro
yes as frank said with a HD2 kit you will have a weak transbrake with a limp mode failure. limp mode forces the trans to third gear and the valve in the HD2 kit forces manual low cant be in 2 gears at the same time
