DEX III or DEX VI for Yank Converters, opinions?
Had My SS3600 for a year now, currently have Dexron VI in it right now which Yank says DEX VI is ok but wanted to see if DEX III would tighting up the Converter a lil, Really no problems just want to see If you guys prefer DEX III or DEX VI for Yank Converters.
GM worked on this fluid for 6 years before releasing it.
DEXRON-VI significantly improved fluid viscosity, shift performance and fluid durability during aggressive driving. GM tests have demonstrated that DEXRON-VI delivers more than twice the durability and stability in friction tests compared to existing fluids. DEXRON-VI has also shown superior performance in pitting, foaming, oxidation and shear stability tests.
OP you will be fine with dex III non synth
Dexron III is trash.
I dont even use it in my power steering system.
Dexron III can suck on these tests to the *****:
http://www.sandyblogs.com/techlink/2...dexron-vi.html
This is great info. It's good to know that you can top off your DexIII system with Dex VI.
Also, there is a very big difference in price between the two, even at the parts stores vs. the dealer.
