4L80E build for 900-1000HP?
I'm planning to get 4L80E built for my daily LS1 383ci turbo F-body. I want it to hold upto 1000HP (that's the most I hope to squeeze from this setup eventually). I can't purchase tranny build by sponsor (a bit over budget, plus shipping to Europe is expensive), so have to get it done locally.
What parts should I get for this build? It's clear after some research that input shaft better be changed but what else is necessary?
Also very important, is there any GOOD rebuild/upgrade kit I could buy?
Check shipping with Concordia Freight for international.
Exports International is a good broker as well.
A whole trans on a pallet may be cheaper than shipping parts and converter to your location.
If I decide to stretch my TC budget to 1K, more likely it will be your converter Based on member's opinions and that yours is lockable in 2-3 gears (don't really know whether I need it, but I'm hardcore stick guy so locked TC is closer to what I'm used to), from $1000 converters I would pick yours. I'm just not yet sure I can afford it
Chris
