trans temp gauge ???
Installing a electric trans temp gauge and if there was a good way to install the sender or get a recommendation for a sender that will go inline with the trans lines going to the cooler up front or if im going to be best off pulling the pan and having a bung welded on to to the pan to put a temp sender in that way
Internet Mechanic
IMO I would want to know the temp at the hottest point so that if there was an issue, I would see it right away. I know in most cases people we as close to the trans as possible some units can be tapped for a fitting or off the pan.
But I'll let the experts speak to that.
Some pics I found....
http://www.mrtruck.net/p_pic/pmlford6.jpg built into the pan.
http://carphotos.cardomain.com/ride_...009_medium.jpg off the line
http://media.photobucket.com/image/4...p/P2170219.JPG DIY off the pan
http://www.dieselmanor.com/diy/PSD3-...-sender3lg.jpg I see them sometimes tapped into the transmission.
if i did the inline on the cooler lines i would put it as close to the tranny as possible on the feed line to the cooler just trying to get some options ... ill prolly end up doing like what you put up on the 3rd picture
already have it the trans temp guage kit ... running multiple gauges so not really looking to spend a whole lot on one that can do a few got the whole kit through a local speed shop for 40 bucks and a aem wideband for 160 to my door
