TH400 burnt 2nd gear band?
Took my TH400 to the shop to get a Hipster brake installed. It has a "hot rod" rebuild (blue clutches, HD drum and sprag...) and a full manual valve body. Shop pulled it apart and told me second gear band is burnt. As I understand it that band only works when you "gear down" in second?? What would make it burn? I'm guessing it must be dragging because I never "gear down." Bought the car used and have no idea if the former owner did. The transmission guy said not to worry about it as he is just going to remove it. Just wondering...
Al 95 Z28, TH400, S-60 w/ 4.30's
