Need advice on 4l60e rebuild
Old Apr 26, 2011 | 09:30 PM
philsblwnz28's Avatar
Default Need advice on 4l60e rebuild
Ok, my 4l60e is slowly getting worse and starting to slip. I would like some advice on a couple of options. I am eventually going to put a 4000 yank in it also. So basically what could I do.
1. Buy all (bulletproof) parts and have tranny shop rebuild.
2. Order an aftermarket 4l60 from a vendor.
Old Apr 26, 2011 | 09:35 PM
z99ls1's Avatar
Restricted User
#2 with (bulletproof) parts installed by vendor
Old Apr 26, 2011 | 09:37 PM
Ellsworth's Avatar
check out RPM transmissions, my dad just ordered a 4l60e with a 3200 stall and he loves it!
Old Apr 26, 2011 | 11:37 PM
01ssreda4's Avatar
I found a local guy who specialized in 4l60s around the drag race guys. Saved some bucks over the internet prices I was seeing. Might not hurt you to ask around with the trans abusive crowd whose trans' are holding up.....All our trans vendors are top notch from what I can tell so you have a fall back plan.
Old Apr 27, 2011 | 05:50 AM
Vince B's Avatar
Moderator
What do you have done to this vehicle? This would help us recommend what trans or parts might be needed to accomplish your goals. Vince
Old Apr 27, 2011 | 03:12 PM
I have done the following mods:
SLP Lid
P&P TB
Small street tune from buddy's lap top.
Line pressure is boosted for trans
Pacesetter LT w/ 3" Y-pipe (no muffler)
Stock internal motor w/ 853 heads 190K miles
Stock 10 bolt with 3.23 (going to 3.73)
98 Z28 weighs 3000lbs w/o me in it
Runs 12.56@111 bouncing off rev limiter going onto 3rd
Old Apr 27, 2011 | 03:32 PM
CorbinLR's Avatar
Buy a built 4l60 from a vendor or a 6l80.
That's my vote.
Old Apr 29, 2011 | 11:02 AM
Specialized's Avatar
That's my vote.
Really? did you READ his mods?
Buy a rebuilt trans from a vendor on ebay, save yourself 1000+$
Your car at 190k miles may or may not make it another 190.. but if you're just now replacing trans then I would say go with another stocker =)
Old Apr 29, 2011 | 12:12 PM
72blownvert's Avatar
SLP Lid
P&P TB
With the mods listed it is a pretty straight forward build.
1.Rebuild kit w/borg warner clutches.2.transgo hd2 kit(install high rev spring kit that it comes with)3.delete the pwm for lock up turn it into on off.4.high energy band.5.dual cage input sprag.6.reinforce input drum w piston & sleeve from sonnax.7. pump slide spring also sonnax.8.beast sunshell.9 new solenoids & seperator plate.10.deep pan. Make sure you put line pressure back to stock in the tune.Also put new accumulators in.
