4l60e pump, only 1 spring inside of it.. shouldn't there be 2?
rebuilding the pump on a 99 4l60e, isn't the spring suppose to have 2 springs, one inside the other? The pump I'm working on only had the outer spring and not the inner. Is this a problem or do I need to go to a transmission shop and get the inner spring?
thanks
thanks
They left the factory with 2.Either someone left it out at the factory or when being serviced,or it has a single super stiff transgo type spring.Is the face diameter of the rings wider than normal? This is how the tgo stuff is.
Moderator
There are actually 4 different possibilities here.
A.Trans go spring which is gray.
B.Sonnax spring which is purple.
C.The late factory spring which the coil tapers on the ends and is heavier than normal only using one single spring.
D.Or the obvious that someone left the inner spring out.
I went and bought the trans go kit
someone obviously tried to rebuild this thing without any manuals or experts to supervise. There are a few parts that are missing along with the pump spring
it was def. suppose to have 2 springs, I took it to a transmission parts shop and showed them and they knew the color difference of the springs. I installed the hardened pump ring kit with their dual springs so it should be good now. Thanks for all the help
If you are using the TransGo "dual spring" setup then it is a low rpm setup, good to 5,500rpm without the pump losing pressure. The "single spring" setup is for hi rpm, good to 7,800 rpm without the pump losing pressure.
Moderator
This is correct however the reason for a heavier spring is not about fuel economy. Are we really worried about fuel economy here? The reason for the spring is so decrease oil pressure on the back side of the slide does not push the slide in the decrease oil pressure direction under WOT. Obviously there are a few things that can effect this as well but a weak spring is just one of them. Vince
