Thinkin about goin to an Auto..
I'm thinkin about pullin the Built T56 Setup out of my MCSS and puttin a 4L80E in it with a 4K Convertor.
The car is setup with a 9"/3.89 Gears, adjustable 4-link in it and some suspension work.
I already have a 4L80E, it just needs a couple of parts to be put back together, I can do the wiring and tune it with my HP Tuners, the only thing I need is the Flexplate setup, Stall, and lines & cooler. Then have the driveshaft shortened and add the 32 Spline Yoke.
Thoughts?
Thoughts?
A stock 80 is no better then a stock 60 IMO. The 80 needs to be gone through to make it better then a 60. But, your car will be faster with an auto.....
It may stock vs. stock be stronger then a 4l60e, but not a built 4l60e. You have got a bad 60 builder right around the corner from you if you ever wanted to go that route. Sending you a PM about the 94 wiring....
The 60 in my green car was good for around 650 lb-ft through a 10 in converter. Honestly, I would have built the 200 you had. I haven't had the chance to dig into the 80's, but I've heard from other builders they can take alot of abuse when built.
Have Tim at Pro1 in Texarkana build you a 60e. He is very highly recommend around the drag community and the price is very reasonable for what you are getting. Don't give up OD going with one of the older trans. And at your power level you don't need an 80.
In my experience and most others, autos ET like a sumbitch. Manuals tend to trap higher. And, autos take a lot less effort/money to get them to work. I literally threw stock size ET streets on and went out and cut fantastic 60 fts, with no other suspension mods. I see the manual guys struggling to keep up. They are running you down on the big end, but its too little too late.
