4l80e neutral safety switch help
Old 06-22-2011, 05:10 AM
mrabel's Avatar
Default 4l80e neutral safety switch help
I have a 2006 4l80e out of a 2500 express van and a 2001 wiring harness out of a chevy 2500 with the 6.0 for my mustang project. My question is the neutral safety switch with the single plug. Is the neutral safety switch interchangable with a earlier one with the double plug as my wiring harness has? Or do I need to change the plug end on my harness? Any help is appreciated. Thanks Jonathan
Old 06-22-2011, 08:29 PM
Emulsifide's Avatar
Check out this thread on LS1tech's sister site:
http://www.performancetrucks.net/for...d.php?t=424904
GOBS of info in there. According to the guy who did a swap from a 4l60e, the switch on his original transmission with two connectors worked just fine. The two connector one for the 4l80e is the same switch as that of a 4l60e. Given that info, the early 2 connector switch for a 4l80e should work fine on your later 4l80e.
I'm going through this swap as well on my Camaro and just picked up a 2008 4l80e with the single connector switch.
Old 06-23-2011, 04:58 AM
mrabel's Avatar
Very helpful . I always end up forgetting about that site. Thank you.
Quick Reply: 4l80e neutral safety switch help
