How to diagnose 4l60e? VIDEO
Ok so I have a 2001 camaro z28, if you have seen previous post, my tranny seems to be going, were im going with this is how can I diagnose what it is? I have a video hope you can tell me what you think it is
http://www.youtube.com/watch?v=PjFojtSXgow
http://www.youtube.com/watch?v=xE5SuDSzxXM
Mine was doing something verry similar to this and a filter and fluid change fixed it. I could barely give it enough gas to gain speed in od and the lockup would disengage. Now it takes almost enough to drop a gear to un lock the converter. So far, so good. Hot summer weather and no trans cooler may have something to do with it. If my suggestion fixes the problem a extra trans cooler wouldnt be a bad idea either...
Mine diesnt even run anymore. If i raise car on all four jackstands. And put in gear. The tirrs turn with progressive throttle. Some ppl have told me its the pump and others swesr its the tq converter. Trans is supposed to be built to handle serious hp and also has circle d tq converter. I bought car this way. The fluid looks new, no metal at all. almost. Also been told could be just clogged filter. Any ideas.
Op sorry for
Op sorry for
the thing is that I do have a tranny cooler, it came with the car so the previous owner installed it, im thinking he did work to the tranny but im not certain, what else can I check one of my transmission line hoses blew and I had to replace most of the tranny oil I refilled it with 5 quarts, and my tranny is still the same so wondering if its something internal now??
