new 4l80e trans
Old 07-16-2011, 12:20 AM
+badss+'s Avatar
Default new 4l80e trans
i am done with my 4l80e swap into my 2002 camaro ss,
what is the best way to break it in?
thanks in advance...
Old 07-17-2011, 04:44 PM
+badss+'s Avatar
no one? anyone?
Old 07-17-2011, 04:46 PM
+badss+'s Avatar
i mean i'm going to take it easy on it for the first 500 miles because i have to break in my s60 also. was just wondering if that would be enough for a break in no wot or anything till 500 miles or more.
Old 07-17-2011, 05:54 PM
JRENIGAR's Avatar
Id be more intrested in how many shifts between gears it sees. I mean, 500 miles can be all in od if your going from florida to arkansas, and there wont be much break in for the other clutch packs if that were the case.
Old 07-17-2011, 06:09 PM
+badss+'s Avatar
Well it's full manual shift. I have to break in my s60 by drive different speeds for 50 miles then let cool 30 mins repeat til 250 miles, then normal driving til 500.
Old 07-17-2011, 07:57 PM
Cam72aro's Avatar
To my knowledge there isn't much break in on a trans. If you are breaking in a new rearend then you will be heat cycling it and taking it easy. The trans will like this as well. Check the fluid after it hot and running. I have never broken in a trans, usually warm them up to temp and then drive it normally.
Old 07-18-2011, 08:37 AM
+badss+'s Avatar
thanks guys.
