Tran crossmember won't line up. Please help!!
Old 10-08-2011, 11:55 PM
djloc79's Avatar
Default Tran crossmember won't line up. Please help!!
I have a L92 engine and a 4L60E trans installed in a 96 chevy camaro which was originally a V6. I was told that I needed a trans crossmember from a 93-97 LT car to fix this problem. After removing the V6 crossmember and installing the V8, I have the same issue. The bolt holes are about 3/4-1" off towards the rear if the car. It's as if the trans is to long for the setup. I was thinking that if I loosened the engine mounts, I could get enough slack to make it work, but 1" is alot. Any suggestions?
Old 10-10-2011, 03:10 PM
1lejohn's Avatar
I would try a LS1 F-body trans cross member. You won't get 1" from the motor mounts. What motor mounts did you use for the 92 to fit the engine bay? You would need the LS1 mounts for them also.
You do have the correct tail shaft on the trans right? It needs to be the one for the T arm to mount up
Old 10-10-2011, 04:12 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
An LS1 F-body transmission crossmember will not work on a LT1 F-body becasue the floorboards are different.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-10-2011, 04:52 PM
1lejohn's Avatar
ok what does he need to do
Old 10-10-2011, 10:21 PM
djloc79's Avatar
Yeah,......what he said!! Lol
Old 10-13-2011, 09:08 PM
djloc79's Avatar
Default success!!! well maybe..
ok, i fabbed up something and installed it. haven't really had a chance to drive it yet, but i did notice that i lost quite a bit of the vibrations inside the car that were there before. i welded a piece of 1/4" angle to the crossmember. here are some photos.....
Old 10-14-2011, 09:24 AM
1lejohn's Avatar
Looks good .
Old 10-14-2011, 09:28 AM
djloc79's Avatar
Thanx
Old 10-14-2011, 11:06 AM
BMR Sales2's Avatar
Either fab something up which he did already or a 4L60E crossember for a 93-97 f-body should of worked for him.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 10-14-2011, 12:46 PM
Blue85350's Avatar
I'm pretty sure I read in one of "the mervs" threads that stock crossmembers won't work at all for that swap.
Old 10-14-2011, 02:14 PM
djloc79's Avatar
Not saying that you are wrong, but.....
Originally Posted by djloc79
The engine is mounted on a ls1 car crossmember. The issue I'm talking about is the holes on the tranny cross member won't line up with the threaded holes. It's about an inch off. As if the trans is too long for this setup. I called it an issue bcuz I saw where it came up a few times in various posts.
You need a LT1 Crossmember
So i guessed wrong in thinking that the v6 and v8 had the same crossmember? (typical)
Old 10-14-2011, 02:41 PM
camaroz28lt1at's Avatar
I did a LS swap into my 95 Z. I have an aftermarket crossmember and had to enlarge the holes to slide it forward for it to work, it did not line up perfect.
Old 10-14-2011, 02:52 PM
Blue85350's Avatar
I could very well be wrong.
Old 10-28-2011, 07:24 PM
runtwrestlin's Avatar
Nicely done. We had to elongate the hole in the crossmember when we did my swap. I wish I had a welder...sigh. So many uses for one
Quick Reply: Tran crossmember won't line up. Please help!!
