how to get the shift handle off of auto?????
Old 03-15-2004, 08:56 PM
redbandit98's Avatar
Default how to get the shift handle off of auto?????
Hey guys, i am needing to remove my "t" handle shifter on my auto so i can remove the console to run some wires. I cannot for the life of me get the damn handle off. There is a notch in the front of the shifter..directly in the front so its facing at the radio.. i tried to stick a falthead in there and pull thinking that maybee that was the release but i guess not. There are no "plugs" that cover any set screws on the handle that i can see..Please help
thanks
Matt
Old 03-15-2004, 09:07 PM
franny40's Avatar
I used a flathead also, but it was one of the eye glass screwdriver type, I just popped it out enough and then I grabbed it with some needle nose pliers and took it out. You are on the right track, just try a smaller type flathead.
Old 03-15-2004, 09:14 PM
thanks ill go bust out my jewlers set
Old 03-15-2004, 10:14 PM
LS1TECH Sponsor
badpewter-z's Avatar
thats pretty much it, use a pick pull the retaing clip out of the handle and handle lifts right off. verrrryyyyy easy
Old 03-15-2004, 10:42 PM
2KThunder's Avatar
Yep, mines fairly easy. It is a U shapped pin, with the forks going into the handle. Just slide somthing in their and grab it with pliers. I might be in there good since you have never removed it before.
Old 03-15-2004, 11:39 PM
thanks eveybody i got it out with no problem.
Old 04-09-2004, 01:55 PM
FenixSS's Avatar
I'm having the same problem with my Camaro's handle, I bought a Trans AM T handle to replace it. I've got a very small flat head, a set of pliers but for the life of me, tried for 1 hour and some odd mintues to get it out. Any other suggestions?
Old 04-09-2004, 10:53 PM
lnuxhakr's Avatar
Along the same lines of this post...Is there a way to remove and bypass the safety push button on the side shift handle. I have limited use of my hands and the pushing the button before putting it in drive can really be a headache sometimes.
thx
Old 04-11-2004, 07:01 AM
FenixSS's Avatar
bumps
