Revmax vs yank
Revmax vs yank
A few people have told me to get a yankss3600 stall but the revmax stall is normally the same price right now with the special until the end of this month i can get the revmax for just around $330 so will i be getting a good deal or should i just get the yank because it is known and proven with our cars? Also with a stock motor, trans, and 2.73 gears should a get a 3600 or something more like a 3200? My torque converter is going out and i cant afford bigger gears right now. Thanks
Your torque converter is "going out".....You sure about that diagnosis?
Here's my Yank 4k in action. 3600 would be similar.....
https://ls1tech.com/forums/multimedi...pics-vids.html
Well either that or a shift solenoid i was going to buy a kit and replace all the solenoids. And get the stall. I just wasnt sure if i should chance the revmax because its cheaper now.
How have you diagnosed that the TC is going bad? The 4L60E transmission is notorious for issues in the PWM/ TCC circuit in the valve body wearing out!
Second to be fair, if you are going to compare apples to apples, you would need to compare our stage 5 billet converter ($725.00) to the Yank SS3600. Both units use the same components, billet front cover, clutch piston and clutch material. Our stage 3 unit is a non billet unit, however, it is a great choice for a relatively stock or lightly modded car such as yours. Now, if you were forced induction I would highly recommend our stage 5, but for your application the stage 3 will be great!
I havent diagnosed it. But after i changed the fluid and filter and the problem continues (as i thought it would anyways) i thought second to replace solenoid and the torque converter. However, i dont know much about transmissions so any suggestions will help.
After it heats up it gets stuck in 3rd gear. When i leave from red lights i have to give it alot of gas to go. And it never shifts first-second or second-third it just gets stuck in 3rd.
Also, you sure it's getting stuck in 3rd? You could have a funky shift selector switch (nuetral safety switch) that is telling it to start in 2nd gear and act like that. Never heard of one taking off in 3rd though. But it's surely possible if something is messed up.
Does your car have one of those 2nd gear start buttons? If I remember right some F body's had one. Make sure that isn't on if so.
take it to a good trans shop likely you will need to have all new solenoids replaced. best to do that while your already in there and change the wiring harness if they offer it do it. Even running a stall on a stock motor helps it tremendously. I run the ss3600 in my Z and i will say it was worth every penny.
I wouldn't be surprised if somehow the trans is actually sticking in 2nd and staying there. You can command the trans to stay in 2nd with the shifter and the 2nd gear start button makes it start in 2nd but I don't know if it any way could ever makes it stay in second the whole time. Something could be going on there.. who knows, either way you need to take it in for a proper diagnoses. And don't go to a half *** transmission shop they will probably tell you to do a rebuild regardless of what is wrong with it.
But in addition also don't be surprised if it actually does need a rebuild, these transmissions have plenty of issues.
On an auto F body the best performance mod you can ever do is a good stall converter, it should be your first mod. Anyone that owns an auto F body will tell you it is the most significant mod you can make. I have a LS1 and run a Yank SS3800 by the way.
Ok its a 95 it has a obd-2 port but when i plug it up it says no link is that because its supposed to be obd-1 i work at jiffy lube so i have "slight access" here and there.
I had the same problem on my 95 camaro a few months back. Replaced some stuff recommended by a shop (1-2 and 3-4 solenoids, VSS sensor) but it still went into limp mode. Note that the shops couldn't read it, they were using OBD II software. Finally wised up and bought the ALDL cable for 95's, downloaded some free software, it was the 3-2 downshift solenoid in the pan. I deleted the parameter in the software just for giggles.. Problem went away. The car drives fine now. Go figure.
As far as Revmax goes, I'm actually placing an order today!
