No Reverse or ANY Gears work, idle doesnt move when shifting
Old 01-20-2012, 11:11 PM
philsblwnz28's Avatar
Thumbs down No Reverse or ANY Gears work, idle doesnt move when shifting
So, I just installed a used 4l60e from a 2002 camaro into my 1998 camaro. I hooked both (2) connectors up. Everything is hooked up, triple checked. I was told the tranny had 70K miles on it. I used the converter that came with the used trans I installed.
So I drop the car, added fluid to it, and shifted through all the gears 100 times, let it warm up for 15 min.
What do I get NOTHING.....It idles at 900rpm's and doesn't move, even when shifting from PARK to REVERSE. It wont even attempt to move at all in any gear.
I checked the voltage at the green round connector, it has 3 out of 20 wires with 10.22 volts.
Old 01-20-2012, 11:15 PM
Predator T/A's Avatar
either the converter wasnt seated in the trans and the pump is now broken. or the trans was a toasted unit in the first place, or you forgot to bolt the converter up
Old 01-21-2012, 12:45 PM
Gingervitis Addict
slow67's Avatar
Either the manual valve isn't hooked up, or you aren't making any pressure.
Old 01-21-2012, 12:47 PM
97badass's Avatar
Did you hook the cable up? If so I bet you need more fluid for the converter or as said you didn't bolt the converter up.
Old 01-21-2012, 08:04 PM
I hooked up the Cable. I pulled it again tonight. Got it down to 30 min.
Old 01-21-2012, 08:21 PM
KEVS98LS1's Avatar
Make sure your filter is in correctly.
Old 01-21-2012, 09:31 PM
Well I found out my problem. I didnt seat the converter in all the way and I broke the inside of the pump. O well, thank god i had an extra one. I should be back on the road when I get my SS4000 from YANK.
Old 01-21-2012, 09:42 PM
senicalj4579's Avatar
Dont do that again. Make sure you seat this one and get a good measurement +add a washer is you have to!
Old 01-21-2012, 09:48 PM
LOL, I just want to HURRY HURRY and wasn't thinking. I also found out that this converter I have is out of a truck 4l60e also. Good think? I don't know. I'm gonna use it till I get my stall anyway, just because I can't wait to haul *** again. Ive been down for over a year.......
Old 01-21-2012, 09:58 PM
Dude you need to take your time doing this. **** that do it nice do it twice bs.
Your using a stall from a truck? If so then idk how thats going to drive. lol
