Huron Speed Torque Converters!
Huron Speed is now pleased to offer Torque Converters. No matter the application, we can have you covered! These are made specifically for Huron Speed per YOUR order and needs. These are not off the shelf converters, but rather built to your specs for your application!
We can cover all applications, whether you have a 93-97 F-body, 98-02 F-body, TH400 converted, 2010+ Camaro A6, C5 Corvette, C6 Corvette A4 & A6... you name it, we can get it done!
We have categorized the converters into 2 main models, the C1 and the C2:
Huron Speed C1 Torque Converter
This converter is good for those cars that are stock, bolt-ons, cam only, NA applications, or even small nitrous use.
This converter is good up to 750 hp
Good for smaller nitrous use up to 4000 stall speed.
If you would like WOT lock-up, we highly recommend the C1.3 with the triple lock up discs
-Billet Cover, Billet Lock-up Piston
-9.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C1.3)
-All converters will have a BILLET cover, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates
Huron Speed C2 Torque Converter
This converter is good for those cars that are Boosted (Supercharged or Turbo) as well as higher Nitrous use.
This converter is good up to 1250 hp
If you would like WOT lock-up, we highly recommend the C2.3 with the triple lock up discs
-10.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C2.3)
All converters will have BILLET covers, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates.
We can offer your desired Stall Speed rating from 3000 on up!
We can offer 9.5"-10.5" sizes as well depending on your power needs, as well as either single or triple disc lock-ups!
These converters will come with Huron Speed engraved on them along with a serial number so we can always identify the unit should you ever want to sell down the road!
Please view on the website for options and such, and as always if you have ANY questions, feel free to ask!
If you are interested in a converter, WE are interested in getting some out there to be tested, so please send me a PM if interested and I can get a few people some VERY good deals to help get the product out there for others to see!
All converters come with a 3 year warranty!
http://shop.huronspeedproducts.com/T...erters_c17.htm
Also be sure to check us out on Facebook and "Like" us to keep in touch with all our current specials as well as our constant new product updates!
Click here to check us out!
www.facebook.com/HuronSpeed
Interested in knowing what is inside your torque converters? No secrets here, VERY high quality components inside!
Billet Cover, Huron Speed engraved!
Billet lock-up piston back side!
Front of lock-up piston, 1.5" wide, .070 thick material!
Hardened 4140 Chromoly Pump Hub and Turbine Hub!
Dual fin braced turbine!
Comparison to a typical single fin braced turbine from the competitors!
-9.5" Converter
-10.5" Converter
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Your car runs great!
__________________
All converters come with a BILLET cover, BILLET lock-up pistons, and a 3 year warranty!
__________________
We have now categorized the Torque Converters into 2 main models, the C1 and the C2!
__________________
Thanks for the interest, hope we can get you set-up!
__________________
__________________
__________________
