Getting Built Tranny, which brand converter? Thinking about REVMAX??
Old 02-14-2012, 07:42 PM
ANTICOP RAM AIR's Avatar
Default Getting Built Tranny, which brand converter? Thinking about REVMAX??
Ok, so my tranny took a **** on me last night... Limped home in 2nd gear. Today, no reverse, 3rd or OD...
The new tranny is being built as I type. Getting the raybestos clutches z-pak and Beast shell.... Solenoids and all that other crap... should be a tough unit. Im pretty much stock but will do an H/C upgrade next summer so I wanna see what this will do with stock motor... Now, Im trying to find a converter. Im looking for something that will flash around 3k now but will obviously go up with more power... Im wanting an end result of 3500 after cam/heads...
My question is, what is the deal with the 9.5 10.5 and 10.75 converters I keep seeing? I am leaning towards a Revmax (If he PMs me back). I just dont know how to choose which stall to get. What stall do I have now? Im assuming I have a stock unit. The current converter has low stall speed and is not painted. 99.999 percent sure its all OEM. I was told that the 60s came with different converters and that I wouldnt know till I took it out. Any help or suggestions?
Old 02-14-2012, 08:34 PM
No one has any input?
Are the converter bolts different between trannys? I need some help.. I have to order a converter asap, my tranny will be ready for pickup Thursday...
Old 02-15-2012, 01:38 AM
JWStevens's Avatar
We've got 3 revmax converters. One is in my DD. All of the ones we have work fine. I'm gonna be ordering another one very soon and it will be a revmax too. Just call revmax and let them explain everything.
Old 02-15-2012, 01:08 PM
Well, after all the searches and reviews, I went with their 3200 for my application. Im fairly stock right now but will add a cam/tune this summer so Ill get a little more out of it... a 450rwhp DD with this stall should be nice...Thanks for all the info guys..
Old 02-15-2012, 08:06 PM
JWStevens's Avatar
You'll like it. Its all I really wanted for a DD. Mine has been a good unit so far. I hope you have good tires. Good luck!
Old 02-15-2012, 11:02 PM
I just upgraded to some 315 Nitto DRs and a 342 rear.... This should put my stock internal car safely into the 12s...(fingers crossed)
Old 02-16-2012, 12:02 AM
JWStevens's Avatar
My car is all stock with 2.73's and it wouldn't even come close to hooking at the track when I put in the converter. I just got a 255-50-16 DR last week but the damn rain won't go away long enough for me to try it at the track. Do you run it at the track?
Old 02-16-2012, 12:15 AM
JWStevens's Avatar
I just saw your profile with track times. PM me and tell me how much difference your converter makes at the track if you ever take it back.
Old 02-16-2012, 12:28 AM
^ will do.. Ive got some weight reduction now as well as a 342 rear end... If I can get a good launch, 12s are a sure thing... (so Ive been told)
Old 02-27-2012, 09:45 PM
1998silverbird's Avatar
I have a 3200 Revmax in my LT1 and love it as well.
Old 03-09-2012, 02:37 PM
Just got the car back and WOW...!!! I cant believe how hard it rolls out... its sooo easy to drive too... lock up at around 45-50... easy cruising but get in it more than half throttle and it really wakes up.... I couldnt be happier...
