Which wire to switch on 60E to 80E?
Anyone know which wire to switch on the 60E harness when installing a 80E? I was told I could use the same connector on my harness and just switch a wire to make it work with the 80E. Harness is a 03 suburban I think and trans is 05 I think.
Thanks!
Thanks!
http://www.performancetrucks.net/for...g-swap-413157/
You dont need a relay unless your running off a 60E tune. With a segment swap into your pcm the above will work for you.
If you did a segment swap then you don't need the relay...
just remove two pins (TCC on/off signal, 3-2 control solenoid soignal) and move the TCC PWM wire, just as the link posted by LS1NOVA shows.
