Noob Question...
Old 06-20-2012, 01:00 PM
8ty8 LS1's Avatar
Default Noob Question...
I've tried searching for something similar, but I couldn't find it. I'm in the process of building a "Cam only" LS7 for my s10 swap. I've been told to use a 4l80e for strength and ease of swap. But is there a better transmission that could be used in terms of gearing? My engine will (and hopefully always be) NA. Maybe a 6l80/90e?? Thanks for any input on this fellas.
Old 06-20-2012, 01:51 PM
Moderator
mrvedit's Avatar
IMHO, the 4L80E has excellent gearing.
I recently drove a 2009 Pontiac G8 with 6L80e; giving a bit of gas, the car shoots forward, but then at the 1-2 shift around 10mph bogs down due to the huge gear ratio change from 4.06 to 2.36. Very strange and not at all to my liking. It seems that for light-weight vehicles 1st gear is useless, but starting in 2nd is not quite low enough.
Keep in mind that the 6L80E requires a specific/matching TCM.
Its also a lot bigger.
Hey, just my opinion.
djsanchez2's Avatar
http://www.vibratesoftware.com/html_...nsmissions.htm
200-4R (GNX trans) has better gearing and can be build stronger than the 4l60e.
Less rotating mass than the 4l80e, good for a N/A application under 600wtq. The only thing is they are not electronic.
Old 06-21-2012, 07:23 AM
8ty8 LS1's Avatar
Less rotating mass than the 4l80e, good for a N/A application under 600wtq. The only thing is they are not electronic, they are vacuum operated.
hmm ok i'll look into that. i'm hoping to be a little over 600whp tho, i'm clearancing and balancing the motor with a lil touch up here and there. i know its a long shot, but we will see. Thanks for the info!
Old 06-21-2012, 07:32 AM
8ty8 LS1's Avatar
the only reason why i brought up the 6l80 was because my girlfriend has a L99 5th gen and I love how that thing pulls. The trans is tuned of course, but i figured if it could accelerate and 4800 lb car that nicely, just think of what it could do with a s10 thats roughly 1000 lbs lighter.
Old 06-21-2012, 08:10 AM
djsanchez2's Avatar
With the 6l80e there are people who either love it or hate it
Also I said 600ft. lbs not hp. I'm sure a N/A 427 isn't putting out over 600ft. lbs. to the wheel. S-10 will be lighter anyways so the 200-4R could be a good combo for it. Either will last longer than a stock 4L60e though that's for sure.
Old 06-21-2012, 08:13 AM
8ty8 LS1's Avatar
lol whoops i misread that one, but you're right, i don't think i'll be near 600 lb-ft either. the one thing i have going for me is the weight of the vehicle
Old 06-21-2012, 09:25 AM
Moderator
mrvedit's Avatar
It will hopelessly spin any tires on your S10 and then prematurely shift from 1st to 2nd (because the spinning tires are at the shift-speed and rpm) and then bog down in 2nd gear.
Like I said, it is designed for heavy cars and SUVs. Something that works well for a heavy car will not necessary be "even better" on a light car. Gearing needs to be matched to the weight.
I would personally never consider a 200R4 because so few parts are available for them; they are becoming rare and expensive.
Also with the latest aftermarket parts available for 4L60E, IMO they can now be built at least as strong as a 200R4. Ask Jake Performance about this as he is also a 200R4 proponent on other forums. Also I prefer laptop programmable transmissions.
Hey, just my opinions.
Old 06-21-2012, 09:34 AM
8ty8 LS1's Avatar
ok thanks! the truck is a back halved ladder bar suspension setup. so hopefully that will help with the launch. Also has a 8.50 certified cage (not saying that i need it, but i figured "hey why not" lol)
Old 06-21-2012, 01:36 PM
Moderator
mrvedit's Avatar
A 4l80e will then perfect fit your "not saying that i need it, but i figured hey why not" philosophy.
Old 06-21-2012, 01:38 PM
oddwraith's Avatar
Anything against a built 4l60e?
Old 06-21-2012, 01:45 PM
8ty8 LS1's Avatar
hahaha nicely put!
no i don't have anything against a built 4l60, but it just seems like the 4l80 would just be a better option durability wise? not sure yet tho, i have plenty of time to decide which trans to use since i'm still piecing my motor together before i send everything to the machine shop. i guess if i wanted to go the expensive route, i could always go with a clutchless 5 speed lol i think that would fit the "not saying i need it, but why not" mentality
Old 06-21-2012, 04:34 PM
Jake's Performance's Avatar
A 4L60E power flow is just "wrong" from a design standpoint. It will NEVER be as strong as a properly built 200-4R until you somehow create more 3-4 apply area (bigger piston for the 3-4) and get rid of the forward sprag and even then, it would be more of an equal.
The 200-4R stuff isn't as readily available and is a specialty deal.
It is also not vacuum operated, it uses a TV cable (correcting other posts).
A 200-4R has a more rigid support design, and uses the same power flow as a 4L80E, just smaller, lighter parts.
In the S10 I would probably use a 4L80E if it were mine (and I'm 4L80E biased) . However it also depends on what you are doing for engine control, primary usage of the vehicle, etc.
Old 06-21-2012, 06:11 PM
djsanchez2's Avatar
My apologies, you are indeed correct about the Throttle Valve cable.
No boys and girls, the 200-4r does not get HBO or Skinimax
