View Poll Results: 1/4 times after swap
1-2 tenths better
9
56.25%
3 or more better
0
0%
1-2 tenths slower
6
37.50%
3 or more slower
1
6.25%
Voters: 16. You may not vote on this poll
4l60e to 4l80e 1/4 Mile Times
Old 10-03-2012, 08:01 PM
Mystery Bird's Avatar
Default 4l60e to 4l80e 1/4 Mile Times
Looking to see who has done the 4l60e to 4l80e swap, raced with it, and what were the approximate results? Good or bad.
Old 10-03-2012, 08:18 PM
wws699's Avatar
I am also curious.. Will be doing a 4L80 this winter..
What brand and size converter are people using? What 60ft's?
Old 10-05-2012, 09:47 AM
TwoFast4Lv's Avatar
Alot of it depends on your power level and the combo you took out to the combo you are putting in.
My car went three tenths faster going to a TH400 because of the more favorable first gear. 60fts went from high 1.5s/low 1.6s to low 1.4s to mid 1.3s
Old 10-06-2012, 11:13 PM
Wyocattech's Avatar
Ive got my 4l80 in but no track times yet. Had to work for the last street drags!
Old 10-08-2012, 05:31 PM
EZZZE's Avatar
Mine slowed two tenths but different converter etc. Hard to tell what slowed it. 99 t/a
Old 10-08-2012, 07:32 PM
What did you use for a converter?
Old 10-13-2012, 08:01 AM
Looks like a hit or miss swap.
Old 10-13-2012, 08:14 AM
2nd Gen Fl 'bird's Avatar
Everyone that has done the swap using same type stall reports 1-2 tenths quicker times. Like said earlier, the gear spacing/ratio is the key. Search "Jake's performance" on here. He had a little bit to say on the topic.
Old 10-13-2012, 08:51 AM
Yes, Jake's has my business when I'm ready to do this, he has been very helpful already. Thanks.
Old 10-13-2012, 11:06 AM
s346k's Avatar
i'd guess slower. you're installing a heavier transmission that eats more power. not rocket science.
Old 10-13-2012, 05:24 PM
That is only a guess though, lot's of people guess and one would think heavier is going to kill ET but I want to hear from experience.
Old 10-13-2012, 05:35 PM
Once again, research the people that know, not speculate.(Jake's Performance threads) Not rocket science. I'm not trying to be cynical either.
Old 10-13-2012, 07:02 PM
Heyfred's Avatar
Default gear ratios
TH200-4R** 2.74 1.57 1.00 0.67
TH350*****2.52 1.52 1.00
TH400*****2.48 1.48 1.00
4L80e*****2.48 1.48 1.00 0.75
TH700-R4**3.06 1.62 1.00 0.70
4L60e*****3.06 1.62 1.00 0.70
Old 10-14-2012, 12:22 PM
Jake's Performance's Avatar
It's not as much "common sense" as one would think.
There are many more advanced details and physics happening here than the weight of the transmission or the internals.
Pumping losses, frictional losses, flywheel effect of said weight, moment of inertia of said weight, the very obvious (to a transmission builder) fact that not all the parts are rotating all the time, and when they are, it may not be at engine speed or even in the same direction. we also have differing gear ratios that give us less or more mechanical advantage AND effect those previously mentioned rotating parts as to how fast they are rotating.
You also have to take into effect the rear gear ratio. It has a profound effect on the rate of acceleration of the trans internals.
The short story is, experienced transmission builders will have a good idea what will work and what kind of losses or gains may or may not be seen.
We've seen 4L60E-4L80E swaps go faster in most cases.
I've been surprised on more than one occasion when doing a swap when I thought we were going to see some ET loss and we didn't see a loss or even saw a gain.
It's usually minimum in any case and I would have to say that the converter for a given combo usually has more effect on ET.
Old 10-14-2012, 07:45 PM
twinturbo496's Avatar
This...
The 700R4 was originally installed in mid 80's heavy, underpowered vehicles that needed a deep first gear to get moving, and OD with lockup to improve fuel economy.
If your car is underpowered, the 80e isn't going to make it faster, but if your 60e keeps blowing up, the 80e will make you happy...
I bet most people choose an 80e because they want an OD trans with lockup that won't break, not because they are trying to shave off a tenth or two at the track.
I switched from a TH400 to an 80e and it ran the same mph.
Old 10-15-2012, 07:43 AM
Originally Posted by twinturbo496
This...
Yes, not looking to go faster with the 80e, altough it would be nice, looking to put something in that I don't have to "freshen up" every two-three years. Even if I lose a tenth I'm good with that.
Old 10-16-2012, 09:53 AM
EZZZE's Avatar
In the 80e I had a PT4000 and a 10 bolt with 3.42's
I ran faster with the 60e and an FTI 4000 and a 10 bolt with 3.23's
I think my problem was mostly due to having a low compression lq4 and L92's that were out of the box stock, putting compression around 9.4: 1 I think.
Old 10-16-2012, 09:57 AM
EZZZE's Avatar
I no longer have that Trans Am, but if I had it to do over again, I would do a th350 instead......but to each his own.
Old 10-16-2012, 10:15 AM
Thought about the th350 and have one of those too, but I really like to drive it on the street in the summer too.
Old 10-21-2012, 11:25 AM
s346k's Avatar
there was a bit of sarcasm in my post. i've personally seen 3 cars do this swap. all went slower. the only cases i've seen quicker/faster results are when using a transbrake or high hp cars (130+). for a stock short car making max of 450 whp i haven't seen any gains.
that is my "personal experience". in this guy's case. trapping 117 beforehand. my experience tells me he will go slower. really won't know until it's done. rarely anything dealing with mods is easy to determine.
Quick Reply: 4l60e to 4l80e 1/4 Mile Times
