4l80e swap in 99 Camaro
Old 01-18-2013, 11:28 PM
SnIpEz's Avatar
Originally Posted by nasty_ss
What's the difference between a 4l80 out of a gas truck vs diesel?
Nothing
Old 05-29-2013, 02:26 PM
MillsMotorvation's Avatar
As far as I know the same except for the convertor.
Old 05-29-2013, 05:59 PM
LongIsland63SS409's Avatar
Originally Posted by NOS LS1
You guys will also need to cut out approx. a 4" by 4" area UNDER the floor in one of the stiffeners underside of car to gain clearance where the new harness / electrical connector will go. This is NOT a through hole. You will just be trimming & cutting out part of the stiffener under the floor.
This wont weaken the floor much especially if you have subframe connectors which you should should have on your car anyway.
You will also need to cut 1 1/2" off each side of the bell housing to gain header clearance with a sawzall or portable bandsaw.
I also used LS1 ARP Flex plate & Converter bolts so i dont have to worry about shearing off converter bolts when i bolt slicks onto the car.
Heres a link for some great 4l80e transmission -6 fittings for the swap from ebay. http://www.ebay.com/itm/6AN-4L80E-GM...3d2b69&vxp=mtr
And these to bring the trans lines forward towards your trans cooler.... http://www.jegs.com/i/JEGS-Performan...rentProductId=
Any pics of the 4"x4" clearance of the body brace for the electrical connector to fit?
My 4L80E conversion is from a 2008 2wd truck.
Thanks,
Mike
Old 12-28-2013, 08:56 PM
RONIN LSX's Avatar
Question
Originally Posted by eLiT3SnIpEz
Earlier 80e's are stronger, and there seem to be less lubrication related failures with those. Much cheaper than a late model 97+ 4L80E. 12 o' clock bell housing bolt isn't necessary at all, won't make a single difference.
Sorry to Necro the thread, but why not keep all the info in one place.
So the pre-97 4L60 & 4L80 are better than 97+?
Old 12-28-2013, 09:14 PM
willizm's Avatar
I think he's referring to the 80e only. I have a pre 97 and works great. Don't really need that top bolt hole anyway.
Old 12-28-2013, 10:07 PM
RONIN LSX's Avatar
Ahhh... I see, thanks!
Old 05-26-2016, 10:22 PM
Joe562mma's Avatar
Default Hello
Im doin a 2005 lq4 6.0 swap into my f body v6 camaro...im gonna need subframe from ls1 right will the ls1 k member work with a adapter plate or would it just be better to buy a 4l80e converter
Old 05-27-2016, 03:14 PM
Need a 4L80E convertor and a LS1 crossmember.
Mike
Old 05-27-2016, 03:17 PM
Joe562mma's Avatar
Mike
Well they sale 4l80e crossmember tubular that or a ls1 regular crossmember eith a converter plate?
Old 05-27-2016, 03:27 PM
Tubular.
Mike
Old 11-13-2017, 09:30 AM
Need4Camaro's Avatar
Bringing this thread back from the dead again,
Will I need a new input / output shaft ? Drive shaft?
Cross member needs to be changed right?
Is the wiring harness the only thing thats necessary to get it to shift? PCM reprogramming?
Is there anything else I would need besides what was listed before?
Old 11-13-2017, 09:53 AM
  #32
Restricted User
JoeNova's Avatar
You'll need to change your driveshaft yoke and U-joint, but the stock driveshaft works fine.
Crossmember needs changed. Wiring harness will have to be altered a little bit.
PCM should be reprogrammed, although its not 100% necessary.
  #33
Restricted User
JoeNova's Avatar
Quick Reply: 4l80e swap in 99 Camaro
