Torque Converter for my Ls1 398 stroker
built a new Ls1 engine for my Chevelle and threw it in the car with the original torque converter that came with the engine and trans from a Camaro. As you might now that converter is a bit tight for any thing but the original Ls1.
I dyno the engine with the that converter and and the resault I got was Torque 580.6Nm @ 4460 rpm and Power 414,0hp @ 5720.
So my question is, wich converter do you think I should go with?
I was thinking of something with a stall at about 2800 rpm, the car is made for street use and some cruise nights. Some dragrace may occur....
To explain tight and loose - with the TCI the car would barely move from a start until RPM hit 2500. With the Circle D or Yank SS, I could accelerate briskly keeping the RPMs below 2500. All this with a 3.42 rear.
part# 70442?
I quote: "Stall speed listings are based on engines producing 230lb. ft. of torque at 2,500 rpm. More torque at 2,500 rpm will give you more stall speed, less torque at 2,500 rpm will give you less stall speed than the stall speed ratings indicated."
From the B&M website.
You want performance,if you didn't you wouldn't have put an LS1 in the Chevelle.
3.51 is a good rear end ratio.
NO on the B&M holeshot convertor.
Do it right and correct the first time and you won't be wasting time and money to correct your 1st decision.
No 'off the shelf' convertor,do it right with a CircleD or Yank(or other).
Took your graph and added to it.
The torque curve flattens out at about 3500,so that would be my minimum recommendation.
Now taking 190HP at 2800 and 280HP at 3500,we'll consider those the 'flash' rpms of the two convertors(2800 and 3500). With a 2800,it would flash/jump to 2800rpm @ 190HP,with a 3500 it would flash/jump to 3500rpm @ 280HP. It would put you immediately into to a higher power part of the powerband(90HP more). With the 2800,you'd be climbing(thru the gears) from 2800 to 3500 just to reach that 90 more HP level. Climbing thru the gears at a lower power level does nothing for performance.
My recommendation for minimum would be Yank SS3600(or CircleD equivalent) up to a Yank SS4000(or CircleD equivalent).
