4L80E makes a hissing sound when in gear
Old 11-16-2012, 03:40 PM
FastKat's Avatar
Default 4L80E makes a hissing sound when in gear
The title sums it up - my 4L80E from a 2003 Express van makes a hissing sound when it's running and in gear. It makes it in both drive and reverse. When you put it in neutral, the hissing sound goes away.
I noticed it after driving for about 200 miles on the highway.
On a side note, I think my first gear is a little noisy too. It sort of whines like reverse in a manual transmission. I'm not sure if that's related or not.
Any thoughts?
Old 11-17-2012, 08:10 AM
FastKat's Avatar
Everybody's stumped? I was thinking maybe it has something to do with the trans fluid filter. Maybe the filter came loose and sucked itself to the bottom of the pan? I had some dents on the pan that I pounded out - maybe something else is going on down there?
Old 11-17-2012, 02:25 PM
Monte4ever's Avatar
My guess is the trans needs to be rebuilt.
Old 11-19-2012, 03:57 PM
maddoglou454's Avatar
Probably converter, but in some cases , the filter is clogged up replace filter and you're good to go. It's worth a shot.
Old 11-19-2012, 08:27 PM
FastKat's Avatar
Thanks guys. It might be my imagination, but I hear the hissing sound when the trans is hot. I will try dropping the pan and putting in a new filter.
Is there any other way to isolate it or isolate it to a converter??? I have HP Tuners so I can command the trans, etc.
Old 11-20-2012, 09:02 AM
Change the filter if it still does it,it is definitely the converter. Do not exceed more than 10% line pressure over factory tune.
Old 07-01-2019, 03:53 PM
gtxracer's Avatar
Bump - having the same issue. New converter, fresh fluid, fresh filter on a pre-96 80e. Only does this when it’s hot - any ideas?
Old 07-02-2019, 07:25 AM
MaroonMonsterLS1's Avatar
Received 1,218 Likes on 782 Posts
Did you really just revive a 7 year old thread?
Try the recommendations posted above...then if that gets you nowhere...start your own thread with detail
Old 07-02-2019, 09:20 AM
gtxracer's Avatar
Gee thanks, how helpful.
Old 07-02-2019, 12:16 PM
Have you tried any of the recommendations above?
They are good recommendations so try them first
Quick Reply: 4L80E makes a hissing sound when in gear
