plastic center support sealing rings on 4l80e
Old 12-02-2012, 07:16 PM
stevebbc's Avatar
Default plastic center support sealing rings on 4l80e
These came in my transtec kit with the teflon rings and a note saying many trans builders use them instead of the teflon rings. They have an L shaped cut in them that butts together when installed. I don't think resizing is necessary. Anybody using them?
Also, I've heard of using a plastic soda bottle to install and size teflon rings. Does anybody know exactly how is this done?
Thanks,
Stevebbc
Old 12-03-2012, 01:51 AM
SnIpEz's Avatar
Just use the plastic ones. Make sure you have some transgel
Old 12-03-2012, 12:56 PM
jeremyfrank14's Avatar
I used them with no problem
Old 12-03-2012, 05:47 PM
stevebbc's Avatar
thks guys
Old 12-04-2012, 12:18 PM
PBA
PBA's Avatar
They will take high line pressure as in full manual TH400's and will not 'Knife edge" as the early cast iron rings. The "teflon" rings work, but are time consuming to install.
Old 12-07-2012, 07:24 PM
DevilDawgDad's Avatar
I prefer the Teflon rings.Use the direct drum as a sizing tool. Easy to install and no worries about braking a ring during install.
DDD
Old 12-07-2012, 08:14 PM
SnIpEz's Avatar
I've actually never broken a ring on any install, just don't open it stupidly wide and it should be fine. Like Dana said, teflon will work but they are more time consuming to install. To stretch them enough to go over the grooves, you typically need to hand tighten them a bit enough to get the drum over nicely enough to not roll the ring or mess it up
Old 12-09-2012, 10:51 AM
carlsonauto's Avatar
DDD
X2 Totally agree!!
Quick Reply: plastic center support sealing rings on 4l80e
