New 4l60e wont shift at WOT!
Just put in a new freshly rebuilt 4l60e. new everything. it shifts all gears nice and firm at normal driving but at WOT it just bounces off the rev limiter and wont shift unless i ease of the gas. any thoughts on what this could be?
Strange thing is when it was on the dyno it didnt do this. shifted fine on the dyno. but next day I took it out for some TNT and noticed it doing this.
no engine lights on or codes showing. no MAF sensor and tuned in speed density.
Your saying when you attempt WOT it neutrals out no matter what gear your in correct? As in attempts to up shift but then bounces off of the rev limiter until you reduce speed and it down shifts? Does it tend to do this with the 2-3 shift or with all shifts? How long ago was the trans rebuilt? Do you have an aftermarket shifter or adjustable shift cable?
I had the same problem when i rebuilt my tranny. I havent raced so i don't know if it got fixed. But I changed alot of thing on the tranny the pan, superserver, shift kit, steel braded lines, and a transmission cooler.
Moderator
(Even deeper pans risk road damage, especially on low cars.)
If it's all gears I doubt it's a pan depth issue. Sounds like the mph is set too high for each gear. Maybe a last minute FAILED tune adjustment. When mine got dyno'd there were no full throttle shifts involved.
Sorry to bring back up but im having the same issue just got back from tuner and he cant figure out why it wont shift at wot and talked to multiple trans guys with no luck on responce. It commands to shift but will just hit off rev limiter unless i let out and roll back into it after it shifts
Pontiacerator
Was any tuning done on the car for the rebuilt transmission? IIRC, the WOT shift command at VS has to be lower than the WOT shift at RPM or it will not upshift. Or vice versa - I can't remember because it's been 12-13 years since I've done any transmission tuning. But we got it wrong once tuning my buddy's car and it wouldn't upshift at WOT.
You need to take a look at the line pressure now.
Take all the normal line pressure readings, and...
Tell us what the line pressure shows as 2nd gear gets commanded.
