torque arm with TH350???????
My dad has a M6 and is wanting to convert it to a TH350. We think we have everything in line except for one thing.........the torque arm. What are you guys doing with it on your TH400's and other tranny's? Thanks in advance.
Chris
Chris
make a cross bar to hook the front of the tq arm to. on my friends car we welded the cross tube to the bmr subframes. i made his tq arm and the cross bar from scratch. but i elieve the bmr or any aftermarket tq arm should have a cross bar.
The Bull
Get a aftermarket one like a BMR or Spohn that doesn't mount to the transmission. It's better in the long run as you will not want all that force transferred to the tailshaft.
I just finished putting a TH400 in my 99' T/A. I had to build onto my existing crossmember for my Random Technology torque arm to fit. Everything came out o.k. but now I have a vibration at higher speeds and I think it may be due to the rigidness of the torque arm being mounted directly to the crossmember. What does everyone think?
The Bull
The torque arm has to be mounted to a swivel. If you mount it directly to the crossmember I believe you are asking for a series of driveline bind issues. Even the factory torque arm is allowed to move in and out of the tranny mount for it. I certainly never noticed any significant vibrations from my Spohn TA that way.
It still has the urethane bushing and the tube can slide in and out of it. Basically I used parts from the TH350 kit and built it the same except I mounted it to the crossmember and not the tail shaft.
the one i made we mounted it solid.just has a single buthing and bolt connecting it to the cross bar. and it was drove on the street with no prob. i would not do it that way if it was a daily driver and the car has since been taken off the street.
