4l60e experts come in! Need help!
Old 08-15-2013, 03:15 PM
JVJLS1's Avatar
Default 4l60e experts come in! Need help!
Hey guys have a question. I believe I have broken my transmission. I hear a very strange noise when I let off the throttle like at 40mph as it decelerates. I put it up on jack stands and let the wheels roll on D. I gave it a bit of gas and this weird swishing noise started blarring. I dropped it to 3rd, then 2nd, then to 1st. When I got it to first the noise was gone. I got to 25 mph in first gear and no noise. I let it slow down a bit then shifted manually from 1st to second and as soon as I shifted to second the noise kicked in, shifted to 3rd, it got worse. then D and noise continued. Weird thing is all 4 gears go in while driving. I even did a few WOT runs on the way home cuz some douche mustang was on my ***. All gears went in just a stupid noise as it decelerates. Its really loud. also I noticed my tranny was overfilled and last thing I did to the tranny was pour in half a quart of lucas trans oil additive because of the 2-3rd shift hitting the rev limiter at the tracks. I drained the tranny a out of fluid and got it to the proper level and issue continues. Also there were bubbles when i drained the tranny fluid. Been reading that bubbles are bad. But what exactly on the transmission could have gone bad? I'm dropping the pan tomorrow to see if there is anything big in there. Will drop tranny saturday. just want an idea as to what to look for. I know I messed up big time with the additive...
Old 08-15-2013, 03:16 PM
JVJLS1's Avatar
If you all need anymore info or a video of the noise let me know. I can probably get one by the end of tomorrow before I drop the pan.
Old 08-15-2013, 08:50 PM
Moderator
mrvedit's Avatar
I don't have the experience to diagnose noises.
As long as you are absolutely sure it is the tranny, and e.g. not the driveshaft or flexplate, it sounds (all puns intended) like it will need to be rebuilt regardless of the diagnosis. There are several torrington bearings and various bushing that could be causing the problem.
If you rebuild it yourself, I would first measure the end play of the input shaft before you open it. Excessive end play will give a hint of what to look for.
Old 08-16-2013, 08:34 AM
72blownvert's Avatar
Sounds like you have a bad planetary. Usually one of the torrington bearings go bad and the little needle bearings get between the gears and destroys the planets. Usually its not just on decel it would make noise on up shifts as well. Are you sure its the trans? A bad ring & pinion could make noise only on decel.
Old 08-16-2013, 01:11 PM
Kristoramirez's Avatar
Symptoms with possible repairs:
1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valve body), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Double check by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the vacuum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace.
5. Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off. R&R. Try not to run or drive the car or further damage could result.
9. No 2nd or 4th gear. 2-4 band is slipping. Servo seals may be damaged (can be fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
10. Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under-hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : Shift A solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
12. Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: Shift B solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
13. No TCC lockup: Brake pedal switches improperly adjusted (always on), TCC solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace TC).
14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are applying due to a cracked or leaking forward piston. Overrun clutches will be worn out after 30 seconds of this behavior. Car can be safely driven in D. R&R.
16. Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products (Firestone stocks it).
17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.
19. Loud bang, grinding sound, loss of all gears, and a binding drive shaft: snapped output shaft. Try to wiggle drive shaft - if more than 0.020" play, that's the sign. R&R.
20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
22. Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
23. 3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS drop-off w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS drop-off -- PCMforLess knows about it.
24. Fluid leak out of the front of trans where the converter connects; partial or full loss of movement: Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
25. Torque converter shudder in 4th while lockup is engaged; problem goes away when the brake pedal is pressed slightly to unlock converter. Have a shop verify line pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a transmission flush by a shop that uses BG brand products.
26. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
27. All fluid pumped out through the vent tube: Plugged cooler line. Flush the transmission cooler and cooler lines. Also could be an over-filed transmission.
28. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels loaded in P, all four forward positions work fine: R&R: Internal cross-leak feeding the forward clutches all the time. Most likely a cracked input housing, or cracked forward piston means forward clutches are fused together. Car can safely be driven gently in forward gears until the repair.
29. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
30. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
Old 08-16-2013, 05:48 PM
JVJLS1's Avatar
Wow thanks I havea few other friends with broken 4l60es. This will help a lot!
Old 08-16-2013, 05:55 PM
JVJLS1's Avatar
You know what I took the pan down a saw no pieces of worn or broken parts but before I went any further trouble shooting the tranny I took your ring and pinion gear statement into consideration and checked the oil. I took the bolt off and as far asI understand if you loosed the bolt and it leaks oil then you have a good level of oil in your rear end. I took the bolt completely off and no oil came out at all. I stuck my pinky in there and I could feel if maybe it was a little low. Its seems really dry and I believe that maybe the problem! Ima take the cover off and inspect the gears and see if I didnt already break anything in there because of lack of fluid. THANKS AGAIN!!!
Old 10-01-2013, 10:08 PM
white2kbird's Avatar
Kristo.. i don't see one issue/fix in there
*Tranny shifts good on all gears at normal driving but sometimes at WOT hits/bounces off limiter only from 2-3rd (1st to 2nd no issues since the commanded shift its low on the rpms) Could this be tps related? its not lazy at all, tranny is a PB lvl2 with 700 miles
Old 12-06-2013, 01:09 AM
JVJLS1's Avatar
It ended uo being the rear end. Had a busted wheel bearing all fixed now.
Old 12-06-2013, 08:35 AM
Moderator
mrvedit's Avatar
Thanks for the update.
With that I don't think there was a single report of noise or vibration being caused by the trans internals. It was always the driveshaft, rear end or trans mounting.
Quick Reply: 4l60e experts come in! Need help!
