4L60E rebuild put in 3k ago, now stalling
is this trans toast? only goes thru 1st gear smoothly. then rpms got to 3-4k, feels strong then will finally go into 2nd but seems like it doesn't go into 3 or 4 rpms stay at about 3500 and i can only go about 55 without feeling like it's gonna blow up..
idk.
could it be a sensor or computer? there's no service lights on or anything, does rule those possibilities out?
even before the rebuild it had a hard shift into first, and that same problem persisted after i replaced tranny w a rebuilt one.. so i kinda thought i had a bad MAF i tried cleaning it a few times, sometimes there wouldn't be a hard shift thereafter but most of the time it would.
what can i do before i have to have this towed to a shop. i live on the highway cant drive it to one)
idk.
Moderator
This sounds a bit like an experience I had once or twice on the drag strip where the car shifted into 2nd but would then not go over 3500 rpm. Let off the gas, gave a bit more gas, went to 3500 rpm and not more. I coasted to the end, parked it to cool off and on restart all was fine. I was logging with HP Tuners but saw no reason for the problem. There certainly was no problem with the trans - the PCM must have "suspected" some problem and gone into an engine limp mode, which I didn't know even existed.
In short, I think you have a sensor/PCM/Tune problem and nothing is wrong with your trans. The hard shifts can also be due to the tune or a sensor problem. I would suggest first hooking up a scanner to look for codes that don't cause an SES light.
thanks for the advice mrvedit. you always come through. now i dont have a professional scanner or anything but i do have an obd2 bluetooth scanner. a friend is borrowing it right now but I will get it and see if anything comes up.
but if it is a sensor/pcm/tune problem, id probably have to have it taken care of by a mechanic?
when i hook up the bluetooth obd2 scanner no fault codes come back. attached is what shows up on the test results..
with no codes showing up what could it be?
thanks in advance
thanks in advance
do you think it could still be a sensor/pcm/tune problem even though nothing showed up on the scanner. or do you think i should have a higher end scanner?
Moderator
As I implied in my first post, I never figured out what my (rare) issue on the track was.
I didn't log trans temp that day; I do now but it has not happened since.
Sorry, I have no idea what your posted scanner pictures are saying.
It acts like the PCM has an engine "safe/limp mode", but I cannot find any doco on it.
