Oil around output shaft
Moderator
It will come out if the seal is worn, or if excessive
pinion angle is causing you a lot of vibe & scrub.
But no, it shouldn't be coming out. Though a little
weep is probably unavoidable, new properly set up
cars don't leak there.
