Trans gurus: 1st gear issue on fresh build 4L80e
Old 05-14-2014, 03:06 PM
11 Second Truck Club
Superado's Avatar
Default Trans gurus: 1st gear issue on fresh build 4L80e
Trans can be manually shifted or commanded via efiLive into 1st gear...but it only binds...loading engine...nothing else.
Shift into 2nd...either manually or commanded...and it frees up and works fine.
Dropped pan today...no carnage found...solenoids are clicking when shifts are commanded as well.
Fresh tranny, converter and motor...currently @ 693/623.
Any assistance would be greatly appreciated.
Thanks in advance!
http://www.performancetrucks.net/for...-shift-528797/
Old 05-14-2014, 11:21 PM
NorthTexasConverter's Avatar
Try this:
Put the shifter in manual 1st. Command 1st, 2nd, and 3rd.
Put the shifter in manual 2nd. Command 1st, 2nd, and 3rd.
Put the shifter in manual 3rd. Command 1st, 2nd, and 3rd.
Report back with the results for all 9 scenarios. That will possibly help determine where the issue is coming from.
Old 05-14-2014, 11:32 PM
Superado's Avatar
Will do.
Thanks!
Old 05-15-2014, 09:51 AM
Superado's Avatar
If the tranny has had the vac modulator mod since day one w/o issues...which it has...
is there anything in a standard rebuild that could cause issues if this mod isn't taken into consideration when rebuilding the tranny?
Old 05-15-2014, 01:02 PM
No, it only controls line pressure.
I have a couple of ideas of what it may be, the tests I mentioned earlier will point us in the right direction.
Old 06-13-2014, 10:42 AM
Superado's Avatar
Solenoids checked and seem to be fine.
Valve body checked and seems to be fine.
Truck will not shift out of 2nd automatically at all.
Both SOLUS and efiLive can command 2nd and up...but still not 1st.
No metal in pan.
Old 06-13-2014, 10:44 AM
Superado's Avatar
Originally Posted by NorthTexasConverter
Try this:
Requesting again that this be performed.
Thanks!
Old 06-14-2014, 09:44 AM
Superado's Avatar
Sumbeach!!!
Tranny is working now!
Changed out solenoids just to eliminate them completely from the diagnosis ...tranny is shifting perfect now...even in 1st.
Quick Reply: Trans gurus: 1st gear issue on fresh build 4L80e
