opinions on tranny cooler mounting with ram air
i have a built 4l60e in my 02 ss 4,000 stall i have a tranny coler now but the temps are high for some reason i wanna get a new cooler and remount maybe in a different location heres a pic
Temps how high?
You have ac?
How are you reading temps?
Make sure both fans are working low and high. I spent endless time and money trying to figure why my temps were so hot. Right side fan ended up not working in high but in low they both worked fine.
I run mine with ssra but I don't have ac. My cooler is massive but even before I had the massive cooler I had a smaller b and m. It was fine then also.
You have ac?
I have a gauge to read temps n it will get up in the 240 range if I let it on a hot day the car has ac I will have to check if the fans are working for sure and I also wanna order a new cooler
It's high no matter where you're reading from.
I used to try to run a cooler with my a/c and ssra a few years ago. I found out pretty quick that doesn't work well.
Make sure your fans are working. Don't just look at them in low. You have to check both fans in high also.
I think if you are going to keep a/c then that cooler needs to come out of there. Put it dope style and even better would be to run a fan in it.
Another thing is these ram air kits are always advertised that they wont make your car run hotter. Its BS unless you don't have a/c. That's one reason I don't run a/c
Tires hooked great tonight ran a 12.92@106.69 1.99 60' ... My last best was 13.16@104.75 2.0982 60' it was 12* cooler that night then tonight outside. N wasn't hooking on same tires
Cheers
Cheers
I just went through the same thing when I installed my ramair a month ago. I really wasn't crazy about mounting it dope style. I ended up mounting the cooler on to the post where the bumper support mounts to. It mounts it perfectly in front of the vent/duct in the front bumper so its always getting air passing through it. Obviously this can only be done if you don't run a front bumper support. I figured i'd post up some pics just to give you some food for thought.
I see in your sig your going with TEA. Good decision
