Powerglide in a LS1
Powerglide in a LS1?
How would this work?
I am guessing it wouldn't be very streeable, but for a track only LS1 what benifit's/negatives is there?
Also how big of a converter would you need to run?
I use a 4400 now would you have to go any bigger or smaller?
I have noticed these tranny's dont like heavy cars, but what is the limit?
Also could you drive it on the street at all or now way?
Thanks
Thanks
Powerglide in a LS1
Also could you drive it on the street at all or no way?
Thanks
BTW. I already posted this in the tranny section but have no reply's, and that is why I posted it here.
Thanks
Suspended Sponsor Account
this is something I have been looking into myself as I am going to a TH400 or a powerglide. the powerglide works best for cars under 3200 lbs(probably a little less actually) from what I have read/been told and have only the 2 forward gears, so for the F-bodies is not usually a good choice. the are smaller and do cause as much drivetrain loss as a TH400.
I'll see if i can get Brad to respond to this in more detail (this is Demon SS using Brad's screen name) as he knows more about this than I do.
"BTW. I already posted this in the tranny section but have no reply's, and that is why I posted it here."
You posted this question in the tranny section (where it belongs) only 4 hours ago.
Merged...
Merged...
They are really made for a light car. If you could get your car under 3000lbs you would probably love it. You are going to need alot of motor and nitrous with a powerglide to get your car moving if it weighs alot.
The benefits would be less drivetrain loss, lighter weight and more consistant to bracket race. The cons would be the standard 1.76 first gear. You could upgrade to a bigger gear, but those sets aren't as durable due to their smaller size.
The standard rule of thumb is the car should be lighter, but I know of a local tranny builder that has run real quick with a glide in a 3500 lbs car.
Another idea is with a t-brake, leaving on the gas the lower first gear may help a marginally prepped track.
Now just give me about 2 months and I'll let ya know how it works.
Currently I have a T400 with Trans Brake. I have talked to some people that say the T-400 is a power killing tranny even compaired to the 4L60E. They say there is normally a 22-25% drivetrain loss using a T-400. I have also talked to some folks that say a powerglide is only a 5% drivetrain loss. If this were true and in a car that made 450 WRHP through a T-400 and had 22% loss then in theory you would gain around 70 RWHP, that is crazy. I personially dont believe there is that HUGE of a difference in power loss but again I am asking a question here which shows I am not real sure.
Has anyone else heard theory's, or seen fact's of HP loss?
BTW there is a Turbo Mustang that comes street racing a couple times a month with a powerglide. He drive about 30 miles per week which is more than I do.
My local tranny builder has been in the business and drag racing for over 30 years. I can only tell you that his claim is there's a 25% drivetrain loss with a 400. I've run 400's in the past on first gen Camaros and still believe in them. Just thought I'd give his theory a try for my 2000 Camaro and run a glide with a top of line converter and a big rear gear. I hope it nets some good results.
