Circle D 3200 stall ?
I been really leaning towards the Circle D 3200 stall, just wanted to hear some reviews from people that run that stall? My future plans are 224r cam and ported 243 heads, would I be leaving alote on the table only running a 3200 stall with that cam and heads?
I had the 3200 from circle d when I was just boltons 12.20
I put afr 205s, cam, and fast 92 intake andwent 11.9....
Then swapped to a bigger converter from circle d and went 11.30
That should tell u that it will leave a lot on the table
The HP series converter is hard to beat for the price. Considering our next level of performance is twice as expensive. Great for a bolton daily driver type car that wants more flash rpm. Let me know if you have any questions.
-Brian
-Brian
Any converter will help and be better than a stock one... Just give Chris at circle d a call and tell him why ur plans are for your car and he can get u what is best.. hell call several converter companies and see what they say too
I have the 3k to 3200 and 2.73 gears I bought the stall cause it matches the range on the cam I got the torqer 2.. car seems kinda sluggish I guess because of the gears it has.. from a dead roll I can get it to spin an slide sideways a bit.. but moving I cant seem to tell a difference... maybe when the cam is installed I can but im always too damn busy. people say I need to lower and turn off the TM for the trans but not sure if that will help or not
LS1Tech Co-Founder
I have a Circle D 3200 in my 5th gen, went 12.0@113 stock internal and bolt-ons only. Have gone back to back 1.66 60 foot times.
For heads and cam thinking to go to their 3600 or 3800.
